MP3 player portable Speakers
I guess I describe the problem first; I was after a descend portable speakers for my MP3 player - it is a small, cheap 2GB one I got on eBay (sent from HK). It is no brand really but the screen is identical with some of IItronics one I see in Argos, I think with the exception of the body the rest is
the same (it has everything IItronics has).
I got iRythms A-460 off eBay again. It worked with AC Adaptor and my Nokia N95 fine. But does not work with 4xAA batteries at all (it doesn't switch ON even). On top of that as soon as I connected it to my MP3 player it blow up the screen. Now although MP3 player works
I can't see which album I am playing or were I am, basically useless (or as storage).
Now questions:
1- Is there a place can repair these (probably replace screen), is it worth it ?
2- I am sending iRythms back to get one that works with the battery and I have another MP3 player (very similar but "aigo" 2GB) and I am worried if I should connect this one. Although Nokia N95 works fine may be the impedence Ohm of this speaker is too low for small MP3 players, or could be that MP3 player was just a rubish model or the speaker was faulty. Any suggestions/ideas welcome....
  • uzin Dec 04, 2007
    Some feedback, I sent back the iRhythms and now got a Logic3 i-Station MIP107, my MP3 player works fine with this one and I am happy with the sound and quality (although batteries don't last long in these speakers).
    I guess the iRhythms was faulty or just has too low input resistance for small MP3 players.
SOURCE: sumvision SV04-M18
hold down the play button for a bit and then it will say welcome
Posted on May 17, 2007
SOURCE: won't connect to computer
Update your Windows media player
Posted on Nov 02, 2007
SOURCE: Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Posted on Mar 10, 2008
  • 5 Answers
SOURCE: no sound
To troubleshoot a no sound issue first you must check your device manager to make sure the audio device is installed properly.
To goto the device manager in XP:
Right click my computer>Properties > Hardware Tab > Device manager.
Look for your audio device in the list under "Sound, Video and game controllers". If it has a exclamation mark or question mark beside it you will need to download the most recent drivers from the manufacturer's website.
Next step is to goto
start>programs>accessories>entertainment>volume control
make sure that Wave nor Master Volume is not muted, and both are turned up.
Third step is to check for onboard volume control, there might be volume controls on the system hardware itself.
If you say that external speakers work and not the built in speakers, then the headphone jack that you plug the speakers into may be defective. As it is always detecting something plugged into it and never turns the internal speakers on.
Posted on Mar 24, 2008
  • 476 Answers
SOURCE: Philips SA6185/02 8GB MP3 Player
It's unlikely to be a fault with the player.
I have just run the Arcsoft Convertor with a DivX encoded .AVI file and it processed correctly.
One possible cause of this problem is that you may not have DivX codecs installed on your PC.
To check this, try playing your .AVI file in Windows Media Player. If it doesn't play, then you will need to download the necessary codecs. Try www.divx.com
If it plays ok, then continue---->
I assume you are trying to convert and transfer directly to the SA6185.
In this case try converting the file before connecting the player and transferring:
Open Arcsoft Media Convertor
Drag the .AVI file into the program window
Click the "Select Player:" drop-down menu and select SA61xx manually.
The "Convert To" setting should default to Folder.
The default folder setting is My Documents/Arcsoft MediaConvertor/
Click "Convert" to start the process.
If this works, then when the process has finished, navigate to the converted file.
Connect the player to the PC, and drag & drop the .WMV file directly into the Video folder of the SA6185.
Disconnect the player when the display says "Ok to disconnect" and restart.
Go to the video option and your movie should be listed and ready to play back.
If the Convert process doesn't work then, the file is most definitely the cause of the problem. If so, post again with details of the file, and how it was created.
Posted on May 16, 2008
MOTOROKR EQ3 folding speakers repair
George-
These aren't repaired by Motorola. Please contact us for assistance.
Motorola Support Find Answers Motorola Mobility Inc
Mark
Motorola Support
Jun 07, 2014 | Motorola Mobility 3.5mm Motorokr Eq3...
How do you hook audio speakers to a portable dvd player
I am guessing that by this question you mean using computer speakers with a 3.5 mm jack with a portable dvd player which might have a 3.5 mm jack or you could get an adapter cable composite audio (red and white) to a audio jack.
Hope this helps
May 03, 2011 | Sony Audio Players & Recorders
What speakers are for MDS JE 330
Any kind you want. The MDS JE330 needs to be connected to an amplifier to use regular loudspeakers, so the choice depends on your amplifier, room size and budget.
You can also connect small active or passive speakers designed for portable units such as mp3 players or those used on desktop pc's to the headphone socket, but the sound quality won't be very good.
Sep 22, 2010 | Sony MDS-JE330 Mini Disc Player
My speakers no longer have sound, even though the green light is turned on and they are plugged in correctly
There could be several small annoyances happening here. The first thing I suggest is try hooking the speakers audio (green) cable to a different sound source, such as an MP3 player, or cd player, or a portable GPS. If any of those devices allow your speakers to produce sound, then the issue is NOT with the speakers, and you need to look at your audio drivers/settings. Make sure your audio driver is installed, and make sure your audio settings are not muted. You can call your pc manufacturer to get help in determining your driver status.
May 17, 2010 | Dell A215 Computer Speakers
How to install philips portable speakers to my hp computer
use a multi-out jack....it will have two out jacks(female) and one pin(male) to be inserted into the audio out jack on the computer, connect your speakers pins(male) to those 2 out jacks....
look for this.....buy it on ebay look for "Audio Spliter"
guess this helps...pls let me know leave a feedback for this solution...
reg
Apr 27, 2010 | Philips SBP1100/37 Portable Speaker System...
How can I get my Proline NK01 louder??
If you want it louder than buy the portable speakers or any speakers with the normal music jack which is used in most of the mp3 players and connect your mp3 player to them. Thanks and please rate.. :)
Jan 05, 2010 | Audio Players & Recorders
I have an mp3 player that i want to hook up to my logitech x-540 speakers but when i do it only plays on the front, or rear speakers depending on which cord i plug it into, is there a way where i can use...
An MP3 player is a stereo device, meaning that it works on two channels - left and right. Therefore a 5.1 speaker system will only play on 2 speakers.
However, if you want to use rear speakers as well, just for the fun of it (you won't get any surround effects, both left speakers will play the left channel, and both right speakers the right channel) you can purchase a "headphone Y-adaptor", that normally allows two people to use two pairs of headphones on the same portable music device.
It has one headphone plug and two headphone sockets in parallel. Plug it into the player, and to the sockets plug the front and rear speaker cables :)
Please come back with a testimonial if helped :)
Dec 22, 2009 | Logitech X-540 Computer Speakers
How do we connect our MP3 player to the surround sound Logitech X-540. It does not seem obvious. We can connect to get some speakers working but not all..
The only way for you to be able to play music on your mp3 player with those speakers is if you Connect the mp3 player to your PC and play the music threw there.remember you cannot use your speakers for portability it has to be connect to a power outlet constantly in order to work
Dec 25, 2008 | Logitech X-540 Computer Speakers
Need Speakers
Bluetooth speakers are no less than any other popular gadgets and they are gaining in success rapidly. These wireless devices are the perfect match between you and your favourite music. Connect this with your smart phone and see how it fills your life with tune. Bluetooth speakers usually come in all shape and size, from potable to wireless and works elegantly keeping that same compatibility and gets connected with almost all kind of phones, whether it's a windows phone or an android and lets you enjoy better music than in-built speaker. PTron Bluetooth speakers will have good bass sound. MOST POPULAR BLUETOOTH SPEAKERS OF 2016 IJ Tech
Apr 17, 2008 | Insignia NS-DV2G MP3 Player
Portable speakers
just specific ones for the zen player?
Dec 20, 2007 | Creative Labs Zen MicroPhoto MP3 Player
47 people viewed this question
 Grubhead
Grubhead
