Question about Casio Cameras
Casio QV-R4 looses date and time settings after changing battery
SOURCE:
  • 374 Answers
SOURCE: set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Posted on Mar 30, 2008
SOURCE: date changes wrong time
thats because analog watches don't know the difference between AM/PM. First reset the time, moving the hour and minute hands another 12 hours will let you know exactly what mode its in (am/pm) first allowing you to set the date correctly.
Posted on Apr 17, 2008
escapement
  • 2338 Answers
SOURCE: had battery changed how do i reset time and date
Visit: www.casio.com/products/Timepiece/ - 20k - Cached - Similar pages
Try to find manual here.
Posted on Dec 21, 2008
SOURCE: set the time and date on casio telememo30
how do i change time settings
Posted on Mar 28, 2009
vladp995
  • 81 Answers
SOURCE: how to set date and time on a casio qa-300 calculator
Are you sure that there is such calculator, look here casio calculators manuals:
http://www.theusermanualsite.com/ex/thread/view/idThread/1647547
Rate me if it helped
Posted on Jul 08, 2009
Can i use a 4GB SDHC card in y Casio QVR30 camera
According to the product specs on Casio's website No, sorry
Mar 07, 2011 | Casio QV-R4 Digital Camera
Won't print date on picture
Hi there.
You have to set the time and date to show on the picture using the camera's menu before you take the picture.
You cannot add the time and date to a picture after you have taken it except with photo editing software.
Go into the camera's menu and select the setup option, scroll down to imprint (or something like that) and set it to date and time, press OK or save and from now on the date and time will automatically added to your pictures when you take them.
Good luck and thanks for using FixYa!!
May 22, 2009 | Casio QV-R40 Digital Camera
Casio Qv-r41
That's why whoever sold it to you, it's broken. Digicams are cheap enough nowadays to purchase new along with cheap large storage memory cards which comes bundled during sales.
Nov 06, 2008 | Casio QV-R40 Digital Camera
System Error oeo1 on Casio Digital Camera QV-R40
Go to the following website:
http://www.oborona.net/stuff/qv-r40/eng/index.html
unfortunately it does not translate very well from its native Russian, but a potted version of what you need to do is as follows:
1. Download the Casio QV-R40 firmware to a safe place on your PC, unzip it, and put a copy of the unzipped binary file onto a blank or spare SD card.
2. Insert the SD card in the camera, and then hold the Menu button pressed in while pressing the On/Off button.
3. A menu will appear on the screen saying Program Update, Yes/No
4. Select Yes and press the SET button.
5. After a short while you should get a message to say the update is complete. Switch off the camera and remove the SD card, and put in another SD card.
6. Switch on the camera, and hopefully it will restart as new. You will need to enter time-zone, date, time etc.
It has worked for me!
Jul 19, 2008 | Casio QV-R40 Digital Camera
System error 0e01
Maximale Kapazität von SD-Speicherkarten bei Verwendung mit CASIO Digitalkameras Error 0e01: It has to do with the maximum save capacity of the used SD-Cards (max. 1GB for following models). You can format the card (somehow, maybe with docking station), then it would only have 1GB capacity...
...found on Casio Homepage...
Bitte beachten Sie, dass die folgenden CASIO Digitalkameras die Verwendung von SD-Speicherkarten mit Kapazitäten von mehr als 1 GB nicht unterstützen. Bitte berücksichtigen Sie dies beim Kauf von SD-Speicherkarten für diese Kameramodelle.
CASIO kann nicht für die ordnungsgemäße Funktion von SD-Speicherkarten in den Kameras garantieren, auch wenn die Kapazität der Speicherkarte 1 GB nicht überschreitet.
Für welche Modelle ist dies gültig?
  • QV-R3
  • QV-R4
  • QV-R40
  • QV-R41
  • QV-R51
  • QV-R52
  • QV-R61
  • QV-R62
  • EX-S1
  • EX-S2
  • EX-S3
  • EX-S20
  • EX-S20U
  • EX-S100
  • EX-M1
  • EX-M2
  • EX-M20
  • EX-M20U
  • EX-Z3
  • EX-Z4
  • EX-Z4U
  • EX-Z30
  • EX-Z40
  • EX-Z50
  • EX-Z55
  • EX-P600
  • EX-P700
Welche Probleme können auftreten?
  • Die Fehlermeldung "CARD ERROR" wird auf dem Bildschirm angezeigt. Die Aufnahme von Bildern ist nicht möglich.
  • Wird die Speicherkarte in der Kamera formatiert, reduziert sich die Speicherkapazität auf ca. 1 GB.
Jun 08, 2008 | Casio Exilim EX-Z40 Digital Camera
Casio QV-40
To tell you the truth.....NO. You can buy a new casio camera for cheaper than fixing your old QV. Alot of times too the QV isn't going to be compatible with XP or VISTA.
Oct 26, 2007 | Casio QV-R40 Digital Camera
Casio QV-R40
hopefully this page will give you some insight to your problem - http://faq.casio.com/faq/qv/faq_type_b.php?PRODUCT=QV-R40&CATEGORY=Power%20Requirements#2876 - hope this helps.
Sep 20, 2007 | Casio QV-R40 Digital Camera
Casio Exilim EX-S600 time and date entry at every startup
Even casio seem confused by this question! It seems that the camera will loose it's settings if the battery is dead or the camera is not connected via USB. Even if the battery is charged it could loose the settings within 24hrs. You can get the manual below: http://world.casio.com/qv/download/en/manual/
Aug 05, 2007 | Casio Exilim EX-S600 Digital Camera
Cameras Logo
95 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
