Question about Mitsubishi CS-40503 TV
Entirely black screen Mitsubishi Model CS40503 SER. 530082
The screen is entirely black, no raster nothing; yet I feel static electricity when it is turned on. The audio works fine. Before the screen when blank, The screen had approximately 4 thin white HORIZONTAL lines spread vertically across the top 6 inches. If it is the CRT, is it worth replacing? I am on a fixed income. Today, is there such a thing as re-built CRT's? More than 50 years ago I replaced many CRT's with re-rebuilt. Now I art my age I would have my son help me if it is worth doing. How much should it cost if I take it to a shop. Labor? parts? I am in A SITUATION WHERE 50% OF THE COST WILL BE PAID BY ANOTHER ENTITY. THANK YOU SO MUCH. I love this TV and at my age, Big & bright is a necessity.
  • 1,153 Answers
Re: entirely black screen Mitsubishi Model CS40503 SER....
  2. Q6c2
  3. Q291
  4. D251
Posted on Nov 25, 2007
0 characters
3 Points
No picture, no menu, black screen, no raster, sound ok
From your detailed description, it sounds that the main chroma processor IC has damaged. Raster means nothing, but the lighted screen that appears, when a TV is switched ON. For some brands, there will be a blue screen; when there is no signal input, and some others will have a bright white screen with some snow.
I advice you to contact any service technician, to get this TV repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 07, 2014 | Standard (CRT) Televisions
No display
You start as we all do at the begining. But where is that?
It's before you even remove the back cover. Being able to isolate the cause of the problem when you don't have a service manual and the only tool you have is a screwdriver to remove the back, is part of the secret of appliance servicing.
When you first switch on a set do you hear a one second hum.
If yes then the degaus is functioning and the ac power cord, on/off switch and fuse are all ok
Is the power led lit and do you get sound. Yes! then 5volt supply to
microprocessor is present, sound stage and power supply are all ok. Do you get a raster (brightness on screen). Yes ! then line driver, line output and frame stages are all ok. If no raster then run the back of your hand across the face of the screen, can you feel the static electricity. Yes, then EHT is present. Turn off the room lights and look through the ventillation holes of the rear cabinet, can you see the faint glow of the tube heaters. If no then you probably have dry joints on the tube base socket or on the flyback transformer. You've done all this and you haven't even taken the back of yet.
Nov 18, 2013 | Standard (CRT) Televisions
The picture wont come on, power is on but screen is black
this a lack of RASTER, TEST AND measure a) , fuse, c. breaker, transformer, filter, diode, rectifier, IC voltage regulator +horizonta output transistor, HV rectifier, and Flyback HV.
God bless you
Oct 11, 2012 | Mitsubishi WS-73907 TV
Green light is on but no picture visible, black screen
lack of raster : test the power supply b) horizontal output c) output transistor d) HV rectifier e) Flyback.
God bless you
Sep 25, 2012 | Mitsubishi WS-55807 TV
Green light is on but screen is black no picture
problem lack of RASTER: test the a) power supply b) horizontal output c) output transistor d) HV rectifier e) Flyback,
God bless you
Sep 25, 2012 | Mitsubishi Standard (CRT) Televisions
CS 35607 Mitsubishi TV No Video
Please CLICK HERE and once you are at the site enter your model no.
Apr 18, 2008 | Mitsubishi CS-35607 TV
No raster, with sound
check your brain go for electric shock to repair your mind as well as your television
Feb 12, 2008 | Standard (CRT) Televisions
TV Will not fire up.
try this,hang the collector pin of the HOT then try to switch on check the voltage its 115v dc,and check also the oscillation drive at the base of HOT take your VOM at 10v ac,ther must be a flactuate at the pointer.if the two procedure are good.plyback is deffective.but if u dont have any measured voltage at the collector of HOT ur problem is in the power supply. mc44608 is use at all old model philips me for wat happend
Dec 03, 2007 | SansuiM1315 TV
No picture but sound is good. Screen is black
Do you feel static electricity on the screen when you turn it on? If you do, you have vertical output failure. If you do not, then the likely failure is the high voltage power supply.
Nov 06, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standard (CRT) Televisions Logo
132 people viewed this question
Top Mitsubishi Standard (CRT) Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Standard (CRT) Television Expert? Answer questions, earn points and help others
