Question about Homelite Garden
How do I connect the white bottle to the homelite 80 bar power washer ?
What is the fuel ratio for a homelite LX30 chainsaw,ive been told 30/1 50/1 25/1 40/1. Which is correct thanks.
Find an oil you like and mix it according to the oil recommendations.
I use Opti-2 in all my 2cycle fuel mix and it's a 100:1.
What the oil manufacturer says to mix the oil/fuel is what you go by, not what the engine manufacturer says.
Opti 2 2 Cycle Oil 34oz EZ Measure Bottle 20112 eBay
Mar 05, 2018 | Homelite Garden
130 bar making weird noise
I'd love to help but need more info. What is the model # and can you describe the problem you having in more detail.
May 25, 2014 | Homelite Garden
Is a gas and oil mix required for homelite bandit chain saw 33 cc. if so how much. just got it from a pawn shop
Yes! Normally 32:1 gas oil mixture is what you will need. The easiest way is to buy the oil in pre-measured bottles (Usually available in 6 packs). That way all you have to do is add one bottle per one gallon of gas.
Hope this helps.
(Don't forget bar oil)
May 02, 2011 | Homelite Garden
Need to change coolant recovery tank can a anyone do it
Yes you can do it yourself
Degas Bottle Removal
  1. Drain radiator (8005) until engine coolant is out of degas bottle. Disconnect radiator overflow hose (8075) and engine coolant vent hose at degas bottle.
  1. Remove power steering oil reservoir retaining screws and position power steering oil reservoir (3A697) out of the way.
  1. Remove degas bottle return hose and clamp. Remove degas bottle retainers and remove degas bottle.
Installation
  1. Position degas bottle in vehicle and install retaining screw and nut. Tighten retaining bolt and nut to 9-12 Nm (80-106 lb-in).
  1. Connect degas bottle hose and clamp to degas bottle.
  1. Position power steering oil reservoir onto degas bottle and install retaining screws securely.
  1. Connect radiator overflow hose and engine coolant vent hose to degas bottle.
  1. Fill and bleed engine cooling system as described. Check for coolant leaks and proper engine coolant level after engine reaches normal operating temperature.
    Item Part Number Description 1 8100 Radiator Cap 2 - Nut (1 Req'd) 3 - Bolt and Retainer (1 Req'd) 4 - Nut (1 Req'd) 5 - Bolt (1 Req'd) 6 - Coolant Recovery Hose 7 - Coolant Return Hose 8 - Coolant Recovery Hose 9 8A808 Degas Bottle A - Tighten to 9-12 Nm (80-106 Lb-In)
Hope this helps.
Zeppelinx12
Mar 08, 2011 | 1999 Ford Taurus
GAS OIL MIXTURE
3 oz. 2 cycle oil to 1 gallon fresh fuel and
to keep your fuel fresh add some fuel stabilizer found at walmart for ethanol blended fuel ( it will say marine formula on bottle) and add it to the gas can you fill your trimmer with ,follow directions on bottle for treatment vs. capacity.
May 14, 2010 | Homelite Mighty Lite Lawn Trimmer
Problem mazanja verige
If you are asking about chain lubrication we use "Bar and Chain" oil (SAE30 with additives to make it adhere).
If your question is the fuel/oil ratio, it is 50:1 - 4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
If the saw is not oiling the bar and chain please reply below with model number (UT-something) below. Vso srečo.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 25, 2010 | Homelite ZR10926 16 Chain Saw
What liquids go in each resevoir?
Coolant in 50% concentration goes into the coolant overflow bottle. Windshield wiper fluid into the wiper fluid bottle. Power steering fluid into the power steering fluid bottle.
You do not need to add any other fluids to these. Do not add water to the washer fluid bottle for example, if you drive in a climate that would allow it to freeze.
Dec 21, 2009 | 2002 Lincoln LS
Replace a coolant reservior on a 1999 ford taurus
If you need Illistration I Can Email it to you Im at
rejakwilson @ aol.com
Removal
CAUTION: Do not mix Standard (green) Coolant with Extended Life Coolant (orange). If mixing occurs, drain engine cooling system and refill with originally equipped coolant type. If this contamination occurs, the service change interval on Extended Life Coolant will be reduced from 6 years/150,000 miles to 3 years/30,000 miles.
  1. Drain radiator until engine coolant is out of degas bottle. Disconnect radiator overflow hose and engine coolant vent hose at degas bottle.
  2. Remove power steering oil reservoir retaining screws and position power steering oil reservoir out of the way.
  3. Remove degas bottle return hose and clamp. Remove degas bottle retainers and remove degas bottle.
Installation
  1. Position degas bottle in vehicle and install retaining screw and nut. Tighten retaining bolt and nut to 9-12 Nm (80-106 inch lbs.)
  2. Connect degas bottle hose and clamp to degas bottle.
  3. Position power steering oil reservoir onto degas bottle and install retaining screws securely.
  4. Connect radiator overflow hose and engine coolant vent hose to degas bottle.
Aug 28, 2009 | 1999 Ford Taurus
Looking for a Homelite 16'' chain saw bar part number PT1637144
You might try psep.biz for the bar. They list some replacement bars that should fit the model number 240 that you listed. If you don't find what you need let me know and I will try another site.
Mar 15, 2009 | Homelite Garden
Garden Logo
51 people viewed this question
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
