Question about Microsoft Xbox 360 Console
Disk Drive When I want open my disk drive to put a new game in it gets stuck. It takes about 20 minutes to get open by keep pressing it
    Problem Solver:
  • 19 Answers
Re: Disk Drive
Sounds like dvd rom tray coming of the giders m8 time to replace through wear and tear
Posted on Nov 26, 2007
0 characters
3 Points
Why My Ps3 Keeps Ejecting BD?
This is a bad drive. I'd replace it immediately before trying anymore disks lest it damage the disks. Usually this occurs when there is a read error. It is also possible there is a disk stuck in the drive, jammed inside, the sensors, sensing the second disk automatically ejects the one you put in. Either way remove the drive and replace it with a PS3 replacement drive. (Note a way to test if it's a bad bluray lense is to stick a DVD in the drive. If it accepts the DVD and plays, then it can only read the DVDs and not the blu ray disks. If this is the case you've blown the blu ray laser, it still needs to be replaced.) If all else fails take it to a tech place and have them diagnose the problem.
Jul 29, 2014 | Sony Playstation 3 (PS3) Console
We can not start any video games or movies,... we heard sound in the console, it is trying to read them but then in the main screen say open tray , like there are not disk in it. could you help us...
Your disk drive is going bad when it won't read any cd's, dvd's, or games it keeps saying open tray. There are different types of disk drives also, to determine yours go to DVD_Comparison.htm (new disk drives normally range between $40-60) and if you choose to repair it yourself you'll need a small flathead & philips head screwdriver and a very small torq bit set to remove internal screws. It takes about 20 minutes if you know what your doing and youtube has a number of videos to walk you through it if you need them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Xbox 360
Most likely your disk or dvd drive is dirty. Run the disk through a disk cleaner and run a dvd cleaning disk through your drive.
If that dos not work, try removeing disk, close drive, turn off console, unplug power supply, wait 10 or 20 seconds, then reconnect power supply and try again.
If that fails, assumeing other disks will read, your disk may have a major flaw. You can check with your local game store, they often have a machine that may restore your disk, (most places that I know of charge like 1 or 2 $).
Mar 10, 2010 | Microsoft Xbox 360 Console
Disk stuck in tray and start up screen displays multiple languages and says box requires service
replace the dvd drive or take apart the dvd drive and take the disk out that wayto take it the console apart remove the feet and there are screws under them and two und the stickers toward the pops off upward,two scres next to controller port 1 and 2. small screw on harddrive bay.take the dvd drive off casing and dismantle.take the disk out and put the connectors back in.test it with the same disk if not works put the system back together if not leave it apart so that ou can replace the drive later.if you got anymore questions feel free to emal me at
Jul 15, 2009 | Microsoft Xbox Console
Games read as DVD
ive found its just a dirty lens the best way if you can is open the console and dvd drive and clean the lens by hand its simpler than it sounds if that dont work it needs a new lens and now you have opened the console and drive its easy to replace. hope this helps dont be intimidated by opening the console its not hard just make sure you have a torq 10 screwdriver
Jul 13, 2009 | Microsoft Xbox 360 Console
My wii won't take any game disk
need new cdrom player, you can try unplugging and pluging it back in.. whats happened is the belt is stuck on the inside of the cdromplayer
May 17, 2009 | Nintendo Wii Console
Keeps telling me to open the tray whenever I put a game into it..not reading any disk
you re going to need a new disk drive i had the same problem and called 18004myxox and they said its a bad disk drive and would cost 100.00 to fix so i went and bought a new 360 insteadf
Apr 17, 2009 | Microsoft Xbox 360 Arcade
2 disks stuck in ps3
You are A ******, try beating yourself with a hammer
Aug 22, 2008 | Sony Playstation 3 (PS3) Console
Disk drive will not open
When I got this problem I put my xbox on its side then straight up and it opened. If You keep a game in it The drive should stay able to open.This is what worked for me.
Jul 10, 2008 | Microsoft Xbox 360 Console
Xbox 360's disk tray will not open
The motor that opens the drive tray could be bad or there could be something stuck in the gears. You may have to take the Xbox apart and pull out the drive and then take it apart to see if there is anything stuck in there.
Jun 22, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Martin Murray
Are you a Microsoft Video Game Console Expert? Answer questions, earn points and help others
