SOURCE: roller brush is not turning on a dyson DC14
http://www.dyson.co.uk/support/help.asp?product=DC07-SY&article=527
here's a link that might help
good luck
SOURCE: Dyson Animal DC14 brush will not rotate. Removed
If this model takes a clutch then it is stripped and needs to be replaced.
SOURCE: My Dyson Animal 14 beater brush will not turn.
It MAY be a clutch issue. I had a similar problem with my DC07 Animal recently a posted a solution elsewhere on this site, but here's the summary. To reset the clutch on my model, recline the vacuum, turn it on it's side and slowly change the carpet/bare floor knob from one setting to the other about 6 times. This apparently reset the clutch and now it works fine. You may also wish to call DYSON. They're very helpful and walk you through troubleshooting before recommending servicing. Their number is 1-866-693-9766. They'll need your model and serial number (located on bottom of uinit).
SOURCE: Dyson DC 25 Dyson Ball animal. The bottom brush
Two things you can do.
1- Remove the brush as if you were going to change the drive belt for it.
Clean the brush as best you can and spray some WD40 on the hard rubber/plastic
pieces at both ends of the brush. Rotate the pieces to work the WD40 into the space
between the pieces and the brush axle.
2- If you have one available, as long as the brush is off, change the belt.
This should get your unit back in operation.
If you find this solution helpful, I would appreciate a Thumbs Up from you.
Thank you.
Paul
SOURCE: Dyson DC25 rotating brush doesnt work
There is a reset button on the side of the brush bar head. Press it.
