Question about Acer Aspire One PC Notebook
PC not booting
I started to boot the pc but its not booting. After connecting it to the power supply it doesn apprear to be charging either. Please help!!
    Problem Solver:
  • 30 Answers
Re: PC not booting
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Posted on Jul 19, 2010
  • 181 Answers
Re: PC not booting
Assuming the power supply is good, sounds like the ac plug where you attach the ac adapter to the laptop has been unattached from the mother board.
What model is it?
Posted on Nov 26, 2007
0 characters
3 Points
Booting up issue
Does it do this with the mains charger connected or only on battery power?
The plugging in the mains charger if not already, wait a couple of minutes and then try switching it on.
If the boots up fine you more than likely have a battery problem.
If it still doesn't start then you either have a power supply problem on the laptop itself or your main charger is faulty and not charging the battery.
You can also remove the battery and try booting it with only the mains charger connect.
Please provide the results of these queries
Mar 19, 2012 | Acer eMachines 520-2890 Notebook
My hp dv does not boot. it seems to be charging battery when it is connected but cannot boot without the battery. It does not show power or boot when on power alone.
bad charging module on motherboard.
Check if your charger brick is working, if are OK, you must send your laptop to a shop for fix the motherboard.
Please rate my solution
Aug 24, 2010 | HP Pavilion dv6000z Notebook
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Laptop was unplugged while still running ans now
This happens when the battery dies and there is insufficient detectable power to run the boot system. You must change out the battery with a fresh one, or plug in a good external power supply to get things started.
You may also need to let the internal battery charge a short time before the boot system sees enough available voltage to start all systems.
Dec 19, 2009 | PC Laptops
I just buy a new battery (10.8 volts 4400 mAh) for my tecra a3 laptop but now i cant boot it without the ac adapter (the battery is charging so its not a connection problem) please help me as quick as...
Full charge the battery first so that it can contain enough power to boot your laptop. Because it is a new battery it should fully charged for the first use.
Oct 31, 2009 | Toshiba Tecra A3 Notebook
Trying to start hp pavilion dv5000 (dv9628nr) it wont start boot page, it just switches off and on for a few seconds at a time. Will do a system restore if i can ever get it to boot up. Any suggestions?
Possibly a power issue? Try booting up with the power supply connected; you can even start up without the battery power connected to the computer, just the ac power supply. It could be a battery issue...hope you find a solution soon.
Jun 13, 2009 | HP Pavilion dv5000t Notebook
Booting problem
Is the cell still in there ? if the battery is bad, the PS will not provide the charge, plus running the computer .try your pc without the cell pack. Only the power supply connected
Hope this help. keep me posted if not
Jun 06, 2009 | Gateway Solo 9500 Notebook
Acer Aspire 1640 power problem
Will the unit work without the battery? The new Lithium Ion batteries can be overcharged and then cause all kinds of strange problems. Take the battery to a reputable electronics shop or Batteries Plus and have them run a voltage and current test. The current test being the most revealing. If either of these is higher than the level printed on the battery, dispose of it. Also, check ACER's web site for battery problems. All the computer manufacturers have had battery problems.
Good Luck
Mar 19, 2009 | Acer Aspire 1640Z Notebook
Acer Aspire One  PC Notebook Logo
558 people viewed this question
Top Acer PC Laptops Experts
Brian Sullivan
Brian Sullivan
Henk de Ruiter
Henk de Ruiter
Are you an Acer PC Laptop Expert? Answer questions, earn points and help others
