Question about Toshiba Satellite Pro 4600 Notebook
Satellite pro 4600 windows 98 fatal error
When ever I startup, I get fatal error, any suggestions?
  • jdalt Nov 28, 2007
    windows 98
  • 51 Answers
What OS are you running on the system? Did you recently install any hardware? If there is a recent hardware install, remove it and try powering on the system on.
If this fails, then you'll need the restore CDs/DVDs from the manufacturer. This will bring the laptop to it's factory default installation. Before doing so, I recommend purchasing a hard-drive enclosure for a laptop hard-drive and backup all important data.
Hope this helps :)
Posted on Nov 26, 2007
Rosetta stone windows 7 fatal error 1141
To fix this problem i would suggest to uninstall this software and scan PC with PC optimizer like Reginout to fix windows internal errors and corrupt registry entries.
Re-install the Rosetta stone. Disable Anti-Virus and Firewall before installing Rosetta Stone.
Jan 16, 2013 | Computers & Internet
Fatal error code
Most likely cause is either Operating System is corrupt or the Hard Drive is failing/failed. To check the failure you would need to put the drive in a different computer and run a Drive check on it.
Sep 27, 2012 | Intel AOpen XC Cube EZ65 P4 Media PC...
Please solve my problem that shows fatal error ie. qp.RES fatal error.
Hope this works write me back if it doesn't. First go to Start -> Run -> msconfig and hit Open. Hit the Selective Startup radio button on the main screen and then hit the Startup tab. See if any references to the program you removed are in here, and un-check them. This should work!
Mar 15, 2011 | Computers & Internet
Fatal error
this error points to locked files during startup, only known to me solution is complete removal of autocad from the system, it as well be indication that insufficient or faulty memory in the system.
i would suggest removal of autocad, reboot, install ccleaner, remove of all junk and clean of registry, then clean re-install of autocad,
if you have less than 512mb ram on winxp or less than 1024mb ram on vista, it can be a problem as well.
Jul 26, 2010 | Autodesk AutoCAD 2006
C0000021a fatal system error the system has
If you see the System Intitialization screen then getting this error... is is most likely a corrupted Hard Drive. Hard Drive needs to be maintenaced and it may take a Tech to do it or someone real savy. Basicly you need to Boot the System from a CD, floppy or thumb drive and run ChkDsk,.. and see if that removes the error. Drive most likely read able on another system...
Jan 01, 2010 | HP Pavilion a1610n PC Desktop
I gets to the startup screen but then Fatal error 05 pops up... Anyone know what it means?
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 12, 2009 | Iomega ScreenPlay
Iomega HDD Fatal Error 05
Jul 05, 2009 | Iomega ScreenPlay
Window shut down automatically and restart, then shut down again... It happened after a window update yesterday lunch time.
Recovery SettingsOne of the things that is quite different about Windows XP compared to Windows 9x (9x is shorthand for Windows 95, Windows 98, and Windows Me in all their various versions), is that one can control how it responds to certain critical errors—those that cause the infamous Blue Screen of Death (BSOD). In Windows XP, the default setting is for the computer to reboot automatically when a fatal error occurs. If that fatal error only occurs when you're shutting down, the system reboots automatically.
If you haven't changed any of the system failure settings, you should be able to see the error by looking in the Event Log. But a better long-term solution is to turn off the automatic reboot so you can actually see the error when it happens—chances are it will tell you enough about itself to let you troubleshoot further. To change the recovery settings to disable automatic rebooting:
Right-click My Computer, and then click Properties.
Click the Advanced tab.
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
Clear the Automatically restart check box, and click OK the necessary number of times.
Restart your computer for the settings to take effect.
Now when you go to shut down and a fatal error occurs, you'll at least see it and it won't cause an automatic reboot. You still have to sort out what's causing the problem, but that gets us to the next section quite nicely.
Nov 04, 2008 | Computers & Internet
Emachine will not start up it says fatal error regeristery not updated, then turns off
Linux and UNIX ld command help -z defs, Force a fatal error if any undefined symbols remain at the end of the ... which are marked lazyload will not be loaded at initial process startup
E-mail CHID: 5369 Unfortunately we were unable to find anything about the Fatal Exception error message you are encountering we suggest you go through the basic fatal.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | E-Machines eMachines Desktop PC
Toshiba Satellite Pro 4600 Notebook Logo
112 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
