Televison & Video Logo
A
Anonymous Posted on Sep 11, 2018
Logitech M-R0007 repeat sequence of eight red blinks. Not a battery issue. Can not get it to work. Please help.
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on May 10, 2008
SOURCE: TV shuts down with Red Light blinking
Thats an easy set to trouble shoot, but you would need the manual called toshiba power supply and shutdown circuit troubleshooter. It takes you step by step on the items to check so you can easilly pinpoint the problem. You can get that manual at the following link, they email it right after purchase and they also provide free one on one tech support so you can get help with it if you need. Heres the link
http://servicemanuals.vstore.ca/
Anonymous
  • 72 Answers
  • Posted on Aug 06, 2009
SOURCE: Dell D600 laptop: the battery status light is blinking rapidly
is your battery going dead
ginko
Ginko
  • 19396 Answers
  • Posted on Oct 21, 2009
SOURCE: KDF70XBR950 red power light belinks 6 times repeatedly
Hi.
You have a power board error, and TV is in protect mode. This had been caused by the power surges.
Try leaving the TV disconnected from power (unplug cord) for several hours, or overnight.
This will allow PSU capacitors full discharge and can fix PSU fault after power surge. If it does not correct the problem , then there is a faulty component.
In that case the TV must be tested and repaired by a technician.
Regards.
Testimonial: "Unplugging overnight did not work. But thanks for the suggestion. Looks like thisis going to be a service call."
Anonymous
  • 14553 Answers
  • Posted on Nov 11, 2009
SOURCE: screen flashes blue, then shuts off
This model had a lot of problems with bad picture tubes--the blue one is the most common to go bad--the tube will pull so much current the set will go into shutdown.
The tubes are only available on a rebuild basis--very expensive and usually not worth doing.
THERE IS ONE OTHER THING YOU CAN TRY TO DO TO MAKE THE SET WORK FOR A WHILE.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the blue will be on the bottom left--it does vary
7.) Once you locate the BLUE screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Blue Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the blue down until the set stays on and then very slowly turn it up until you see a slightly blue screen with or without diagonal trace lines----if you get it to turn on this way turn the blue screen back down slowly until the blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the blue screen down a few times to get it to stay on.
IF this works you may only be buying yourself some time--if it is the blue tube causing this sooner or later it will repeat--I have seen several sets where the adjustment allowed the set to work for another year or more.
If this told you something you did not know, rate this solution as I do this here for FREE.
SD TECH
Testimonial: "This fix did help temporarily, but had to take the blue completely out and it still flashes. I think it may be a lost cause and not worth fixing."
Thomas Spears
  • 33 Answers
  • Posted on Oct 26, 2010
SOURCE: I have a new Logitech
First: Recheck battery placement - positive and negative ends of batteries must be correctly positioned. Your keyboard batteries have a 3-year life, so they should not have any problem after using your keyboard for only a month.
Second: Most Logitech (and other brands) have a one-year warranty. Since you're already having problems with your keyboard I would suggest returning it to place of purchase for replacement.
Third: Refer to Logitech's problem solving page: http://www.logitech.com/en-us/434/6007?tabs=1,3,2,4,5§ion=overview&hub=1
Battery charger on my Evatac flashlight blinks from red to green repeatedly when connecting batteries to charger what is going on
If the battery charger on your Evatac flashlight blinks from red to green repeatedly when you connect the batteries to the charger, it could indicate a problem with the batteries or the charger itself.
Here are a few possible reasons why the charger is blinking from red to green:
The batteries may be faulty or damaged. In this case, the charger may not be able to charge the batteries properly, causing it to blink from red to green.
The charger may be detecting a problem with the batteries, such as overcharging or overheating. In this case, the charger may be designed to stop charging and start blinking from red to green as a warning.
There could be an issue with the charger itself, such as a loose connection or a faulty circuit. In this case, the charger may not be able to properly charge the batteries, causing it to blink from red to green repeatedly.
It is recommended to check the batteries and charger for any visible signs of damage or wear, such as corroded or dirty connections. If the issue persists, it may be best to contact the manufacturer or a qualified technician for further assistance.
Apr 19, 2019 • Drills
Sonytv bravia model# kdl55ex723 wont turn on red light blinking
The blinking red light should be blinking a certain number of blinks pausing briefly then repeating the blink sequence. If so whats the blink sequence?
Sony Grand Wega Projection TV 2005 Replaced lamp in it, turns on but screen doesn't do anything and the red light next to the power button blinks. I think it just needs a new color wheel but I...
Take a close look at the red light blinking to see if it blinks in a sequence, for example 4 blinks, pause and repeats the sequence, that would be an error code.
2helpful
Hi, I have i Sony wega tv when i turn it on green and red lights flashes and nothing happens please help
The red light is key to your issue---is it blinking in a sequence--constant blink or for example 3 blinks, pause and 3 blinks?
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
I have a new Logitech K340 keyboard, which I have used for a month. Yesterday the on/off indicator light started blinking green and red and stopped working. I have replaced the batteries, have tried...
1helpful
Receiver blinks green, wireless controller blinks red and does nothing
hold in the button on the top of the receiver until it is a solid green then press any button on the controller
2helpful
2answers
My logitech mouse has a blinking orange light one it
had a similar problem. i took the new batteries out again and WAITED about 20 seconds before putting them back in. the red light stopped blinking.
Battery will not charge
Here is how you fix the problem (without using a 9V battery method...).
The battery doesn't charge because it's been fully discharged.
What you do is you put the camera into the cradle. Now you see that the Red LED comes on solid for a while. It's charging for a few seconds. Then it starts blinking. When it does that - TAKE THE CAMERA OUT of the cradle.
Now put the camera back and repeat. Do this six or eight times. Each time what's happening is that the battery is getting a tiny bit of charge. After 8 times the LED will come on red and stay solid red.
Bingo, no problem!
18helpful
17answers
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Top Logitech Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
