Question about DeLonghi DCH4120 SafeHeat Ceramic Compact Heater
DeLonghi DCH4120 heater will not oscillate
After I accidentally tipped over the unit while it was on and oscillating, the oscillation of this heater no longer works. When I press the foot pedal to turn on/off the oscillation, nothing happens? Is there an easy way to open up the unit and fix this? Anyone else have this happen to them?
2 Suggested Answers
  • 108 Answers
SOURCE: DeLonghi DCH2590ER heater problem
I am sorry to say this but these heaters dont last. I have replaced mine recently, An infrared propane heater has a long life and that is what I am using. Hopes this helps
Ray
Posted on Nov 08, 2008
Unable to assemble AM07 fan unit to base. Fan works on cool but will not oscillate. I got base connected with no problem.
Oscillating fans usually have a drive pin that needs to be pushed in or pulled out to get them to oscillate. Have a look for one of these. They normally look like a knob or button sticking out?
Nov 19, 2016 | Dryers
New Dyson AM09 hot/cool fan does not oscillate
S Adams, return for refund or replacement, sound like plastic gear inside could be damaged or loose. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.dyson.co.uk/support/am09/am09-white-nickel/my-machine-is-not-working/my-machine-is-not-oscillating
https://www.dyson.com/support/am0112/am01-desk-fan-12-silver-iron/diagnosis-root-menu/my-machine-is-not-oscillating-am01
Dyson AM 02 Fan not working oscillating feature is broken
http://www.dysoncanada.ca/en-CA/support.aspx
Jun 20, 2016 | Dyson AM09 Hot Cool Fan Heater
Why won't my fan oscillate?
There is a little arm attached to the motor that makes the fas oscillate. If it gets disconnected you will have that issue. Check the linkage.
Feb 29, 2016 | Dyson AM05 Hot Cool Fan Heater
Why wont my dyson fan oscillate?
Hi there, it's Jack at Dyson.
Your Dyson Air Multiplier AM01 desk fan should oscillate when you press the oscillation button on the base:
If you find that it's not oscillating when this is pressed, we'd need you to contact our Support team directly - we can confirm if we're able to resolve this for you under our free 2-year parts and labour guarantee.
You can reach us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 08, 2014 | Dyson Air Multiplier 10" AM01 Bladeless...
My Lasko 5307 oscillating ceramic tower simply does not "turn on" .... what's up?
Electricity is not suitable for use by you....
Check power point with another appliance. Check heater switch, high temp, etc....
Oct 16, 2013 | Lasko 5307 Oscillating Ceramic Tower...
Heat does not come out of defroster
An oscillator? :vibration, motion like a pendulum, pulsation, fluctuation, rotation...yeah, I can imagine Nissan calling a door that swings back and forth to direct air, an oscillator. Hope someone is not pulling your leg, though, or we've both been suckered ! Don't know what to tell you, except to find your nearest oscillator outlet supplier. In the meantime, check the controls to the various doors on the heater case. Are they vacuum controlled, cable controls, or electrical motor controlled? Usually all of one type. You may be able to see the offending part, a disconnected hose or cable, or the stem of an inner door that has broken or not moving the door. The oscillator might be hidden deep in the bowels there-be careful. Good luck, norman.
Feb 25, 2013 | 2001 Nissan Quest
The heater no longer moves from side to side. It's an oscillating heater. How can I fix this?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Oct 05, 2010 | Honeywell HZ370 Space Heaters...
Oscillating burner elements
it is normal for elements on a hob to oscillate on and off. the period on/off is determined by what you have set regulator to
Jul 11, 2008 | Jenn-Air JES9750AAS Electric Kitchen Range
DeLonghi DCH4120 SafeHeat Ceramic Compact Heater Logo
89 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
