Question about JVC AV-48WP30 48" Rear Projection Television
JVC AV-48WP30, DVI to HDMI on Toshiba HD-A3 HD DVD
Is it possible to connect successfully somehow to the "digital-in" on the back of the JVC? I have an HDMI/DVI cable, but I have to use component cables instead, because obviously, the digital dosen't work.
  • 87 Answers
If a kit is available it will be expensive to buy and install. Most people can't see the difference between digital cables and component cables
Posted on Dec 23, 2007
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
HDMI to DVI gives pink screen
try a regular video input on the tv and on another tv, and if that pink is on both tv's then its the dvd but if it only does it to that tv your hooking it up to then there is a problem with the tv video input
Oct 12, 2008 | Televison & Video
Sky new zealand say my hd z70rx5 is unable to recieve hdcp even though the specs say the set is HDMI AND HDCP complient,they say no rear projection is able to receive hd is this true,any help i would be...
Terminals and Connections Dual HDMI digital inputs with HDCP (High Definition Content Protection) offer an uncompressed solution to the transmission and display of high definition video and audio content. All JVC HD-ILA TVs also include dual auto sensing component video inputs, assuring the best possible picture quality whether a viewer is using DTV, D-VHS or DVD, and three S-Video (two rear, one front) inputs and four AV inputs (three rear, one front).
hdmi.gif High Definition Multimedia Interface
HDMI is a new standard digital connection between A/V devices, such as a set-top box, DVD player or A/V receiver, and a digital television. HDMI offers exceptional video and audio quality with a single quick-disconnect connector. It supports multi-channel digital audio transmissions and component video color spacing for true rendering of HD video.
We carry a full line of high-performance HDMI cables. See them here...
Audio Features The JVC BBE High Definition audio system with Advanced HyperSurround and Active Hyper Bass includes two direct-drive speakers mounted underneath the screen for rich, expansive sound that fills your home theater or TV room.
Aug 06, 2008 | JVC Televison & Video
Hitachi 65f710a
u need an AV cord that terminates to an HDMI outlet then u will connect the AV PLUG SIDE the one that looks like the recording video plugs to the DVI links on the back of TV and the HDMI END to the source say a dvd with hdmi interface or set top box THEN TAKE THE tv REMOTE AND SELECT COMPONENT or DVD on tv n u will be good to go HD
Jul 13, 2013 | Televison & Video
JVC AV-48WP30 : no sound comes out of the tv when my hd cord is hooked up. it will play sound through standard hook up. please help
The "hd cord" you're using is probably a DVI cable; they don't pass audio. For this to happen, you need an HDMI cable.
Apr 05, 2010 | JVC AV-48WP30 48" Rear Projection...
Can't get hd there's no signal from the TV DVI connection? what DVD are you trying to drive with this connection?
Feb 16, 2008 | JVC AV-65WP55 65" Rear Projection...
Toshiba HDDVD Player Model HD-A3
well your TV has a 1920 x 1080 Pixels hi resolution is this what you mean?
I would hook up your HDDVD via HDMI to the TV and the regular DVD to Component1 on the TV,
hope this helps
Jan 13, 2008 | Sharp LC-45GD7U 45 in. HDTV LCD
HD-A3 Movies Don't Play Video, but Menus are fine?
Might be a resolution issue, the menus are most likely in 480, while the video might be in a resolution not supported by your tv. Try changing the resolution and see what happens.
Jun 29, 2008 | Toshiba HD-A30 HD-DVD Player
Converting up to 1080
Hello. You have to use the HDMI port and connect to the HDMI, or DVI, port on the back of the TV to get 1080. Even if playing HDDVD, this cable is necessary to get the increase. That, and the TV has to be in 1080 too. If you look at the display, on the front of the player, while watching the DVD, it will tell you at what resolution the DVD is playing. The HDMI to HDMI/DVI must be installed to get the increase in resolution. I have a Panasonic HD 34" 1080i widescreen TV, with DVI connection. When connected, the player played my DVD's at 1080i on my TV, while at only 480i thru the composite cables.
On some older movies or series(I like Star Trek- TNG), it doesn't work well due to the transfer to the DVD. Most newer DVD's, such as Batman Begins (there is an HD out, but I have DVD only), improved on the upconvert for me nicely.
Jan 21, 2008 | Toshiba HD-A30 HD-DVD Player
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
JVC AV-48WP30 48" Rear Projection Television Logo
208 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
