W205kw washer the washer constantly drains it will not fill up
  • 1996olympics Dec 05, 2007
    My whirlpool washer will not fill up it drains right out. There is no puddle on the floor. It continues to go out the drain hose. I have shaken the tub thinking it may be off balance. I have flipped switches. This problem is intermittent. any suggestions. Thanks!!
Thank you your awsome seems to be working
Posted on Nov 25, 2007
  • 213 Answers
Check to see how much drain line is in the stand pipe in the wall. there should only be about a foot of drain hose in the pipe any more that that will cause a syphon efect that will suck out any water that goes in. also, the stand piper in the wall bhind washer must be as tall as the washer itself.
Fills Constantly
check the drain hose. Is it in the drain below the fill line of the washer?
In other words -- the drain line should be above the level of the washer lid top and in the line about 4-6 inches
Feb 20, 2014 | GE GTWN3000MWS Washer
Washer doesn't fill with water and begin wash cycle. I can hear it instantly draining out rather than fill, and has ran my well dry. We replaced the water pump a month ago, and it washed a few loads of...
Sounds like siphoning. This can happen if your drain pipe is too low and you run the drain hose right into it, or if there isn't any kind of air gap between the drain hose and pipe. Usually it shows up when trying to fill for the rinse cycle - it drains as fast as it fills. Or it might not fill at all. Order a "siphon break kit". They're cheap and easy to install
May 26, 2010 | Roper RAS6233KQ Top Load Washer
Kenmore 90 Series Heavy Duty Top Load Washer Model 110.28922790 water fills in tub and it's draining at the same time. Won't go through the normal cycle just keeps filling and draining. Any help...
You may have a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Apr 17, 2010 | Kenmore 22442 Top Load Washer
My maytag washer, will not fill w/waterit runs in
Check your drain hose. It only goes into the drain stand pipe from 4 to 6 inches. Insertion any further will creat a siphon and constantly drain the tub. The stand pipe needs to be at least 36 inches from the floor.
Dec 30, 2009 | Maytag HAV3460AWW Top Load Washer
Washer will not fill up
Jul 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer filling over and over
Check the placement of your drain hose. This may be a simple issue of siphoning. The following link explains:
Make sure you have a sufficient air gap at the top of the drain stand pipe, and that the drain hose is not placed in the standpipe too deep. This can cause the water to constantly siphon out of the wash tub and the washer will continue to fill to try to maintain the water level.
Please let me know if you have questions, or if you require additional assistance. I hope this helps you.
Jan 19, 2009 | Frigidaire GLWS1649A Top Load Washer
Washer Fills/Drains at the same time
check that the drain hose saises above the water level of the tub. I f the hose does not come above the water level, the water will just drain right out
Dec 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
LAV3600AAW Maytag Top Loading Washer
check your house drain make sure it is above water line in tub
Nov 30, 2007 | Maytag SAV5710 Top Load Washer
Washer fills and drains repeatedly
Have a look at the routing of your drain hose. It sounds a bit as if: a. The highest point of the hose isn't high enough (you normally want to aim for about 3 feet off the ground) - so that water starts draining from the machine before it is finished filling. and b. There isn't an effective air break or anti-siphon valve where the drain hose goes into the domestic drainage system - so that once the machine starts to drain by itself, it continues until empty. A.
Jun 07, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
