I have tried changing the batteries already
Check the battery orientation is correct. Otherwise your camera probably has a bad driver board in it. These camera don't appear to be very robust and exhibit a number of faults. Found a similar line of problems on another site -
Fujifilm Instax Mini 8 Troubleshooting
SOURCE: samsung hcm4216w
The most common problem for those symptoms are convergence amps. That unit takes two stk392-040 Sanyo Ics and will most likely require that several low ohm resistors (3.9 ohm-2w) be tested and possibly replaced.. There is one last thing also, a pico fuse at Fd102 (3.5a) that sometimes opens and would need to be replaced..
The convergence board in these is easily removed, so an in-house service call could be done...
Hope this helps
SOURCE: fUJIFILM FinePix A360
my A360 digital wont turn on it flashes green then goes off i put new batteries in it
SOURCE: My Fuji Instax mini 7s
welcome to our websit:... ╭══════════════╮ ..... http://www.voguecatch.us ... ╰══════════════╯ Wow! This site: Both cheaper and fashion, and good products. Purchase will have small gift to send. http://www.voguecatch.us was a good site. Like this discovery. ... http://www.voguecatch.us ...... ***★Nike☆jordan s-h-o-e-s $30--35★*** ****☆ Best online store ☆**** ******(U-G-G)******* ... http://www.voguecatch.us ..... ....Welcome you to visit thanks..
SOURCE: how to known if there is nothing wrong just by looking at the fuji instax mini25
try take some photos on the spot
I have the exact same problem
and i still have no idea what to do with it
i tried changing the batteries and everything
but it just wont turn on
there are no lights where you change change you settings
and i can't take any pictures with it
someone please help
