Question about Amana Heating & Cooling
My AMANA PTAC unit model # PTH093b35ae is not producing heat. My air conditioner works fine. So, I get cold air. However, when I switch to heat, it still runs but does not produce any heat.
Usually when I switch to heat a 2nd fan or something kicks in and then it starts to blow heat but it doesn't do that anymore.Is that the compressor or heat pump? I have no idea if it's the same thing. I have one of the older units so mine is not digital I have knobs instead. Edit: I fixed it myself. I changed out the control board which was a simple fix. Thanks everyone
  • 26 Answers
Check the heater fuses or breaker. If fuses are damaged replace with new ones. If breaker trips reset breaker. Check heater contactor for defective contact point and defective holding coil. If contactor is found defective replace contactor. Check also heating coils for damage and defective thermal sensors. Replace defective parts found.
Posted on Sep 26, 2018
    Sergeant:
  • 301 Answers
It is not switching from cooling into heating. You probably need to have a service tech look at the unit. Sorry. It could be control board or stuck reversing valve.
Posted on Sep 11, 2018
2 Suggested Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
  • 2699 Answers
SOURCE: Hi, I have an amana
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Posted on Jul 09, 2011
I have an amana heat pump a/c PTAC unit 14700 btu and it seems the compressor is not engaging or blowing cold air
could be a bad run capacitor or the unit needs to be cleaned take it outside and wash the condenser coil the outside coil and the evap coil on the inside be careful not to get the electric circuits inside the unit wet. I would wash the coils first and then see if it cools. Hope this helps
Aug 13, 2014 | Amana PTH123B25AJ Heat Pump Air...
If you unplug an Amana PTAC unit and it freezes what could happen?
If you are not going to run the unit put a large bag over the out door section. The unit will be just fine.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 08, 2017 | Heating & Cooling
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
Jun 19, 2010 | Amana PTH093B35AM Thru-Wall/Window Air...
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
Amana ptac
you have the white wire on the wrong terminal put it on the same terminal as the red wire on the capacitor and you should be fine,
Dec 27, 2008 | Amana PTH123B25AJ Heat Pump Air...
Need parts for an Amana PTH123A25AA PTAC
The Amana parts line # is 1-800-227-2919, you can also obtain parts numbers and names from their website, www.amana-ptac.com.
Please rate this answer and let me know if this helps.
Dec 13, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
Nov 18, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
195 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
