Question about Toshiba Qosmio G25-AV513 Notebook
Toshiba Qosmio remote controller not working.
My remote controller has ceased to work -- and I can't find the reason. When I press any of the buttons on the controller, the little red light on the front of the computer shows that it's receiving the signal, but the computer doesn't respond.
I've been looking for a driver or a "switch for the controller, but I haven't found anything. (???)
  • 51 Answers
Re: Toshiba Qosmio remote controller not working.
Try re-installing the software from Toshiba's website.
Hope this helps :)
Posted on Nov 26, 2007
0 characters
3 Points
Toshiba qosmio f50 power button flash no startup
You have to put back the same 8 gB kingston flash drive for the operating system.
Apr 08, 2012 | Toshiba PC Laptops
Hello After i installed the new windows-7 ultimate 64bit, my FN key ceased to function. i tried many solutions amongst them downloading drivers from the Toshiba site, but still not working. How can i make...
Your Laptop has no support for windows 7, never mind the x64 version.
The last supported OS was XP.
If the FN keys are the only thing not working, you have been very lucky.
You may get some help by searching X64 windows 7 forums
Jul 21, 2010 | Toshiba Qosmio G15 Notebook
My laptop Toshiba Qosmio F45- AV413 doesn't turn on. When I press the power button looks that will turn on, but shut down right after. All the lights looks fine, when I plug the power cable the light turn...
Take the battery out & see if it works then, perhaps the battery is so flat it is holding down the PC. It will should go on just the adapter. If this works, then you will have to plug battery back in, & adapter and leave alone for at least 8 hours. If it still won't work, you may need a new battery.
Mar 11, 2010 | Toshiba Qosmio F45-AV412 Notebook
Unknown pass word for Toshiba Qosmio G35
First the safe mode start up key is F8 if you press this as soon as you see the manufacturer logo on startup should bring up another menu manufacture logo would be dell hp ECT. . . Second if you haven't set a password sometimes just pressing enter on the keyboard with the password blank will Log you in. The reason you would you safe mode is some computers have an administrative safe mode account that does not require a password unless it was changed in safe mode hope this helps if you have any questions please comment
Jul 31, 2009 | PC Laptops
Help with Toshiba G15-AV501 Qosmio bluetooth!!
The solution to your second problem is to insert the CD Qosmio Player Recovery CD. The buttons on the top do actually work (most of the time) yet it seems for some reason qccasionally it takes the CD refresh to get them working again. The picture and sound are great once you have got them working. So, don't be discouraged it's a great PC (once you have resolved your problems) I have had mine for 3 years w/o problems except for this one just described. Good luck.
One other thing I did have trouble with the Bluetooth, I resolved it by buying a Targus Bluetooth dongle, (disaabling all built in Bluetooth) then everything "paired" and worked easily, (unlike the built-in)
Jun 13, 2008 | Toshiba G15-AV501 Qosmio Notebook
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Help with Toshiba Qosmio G35-AV600
go cmos by pressing F2 after powering on then change sitting of FN in cmos...
May 02, 2008 | Toshiba Qosmio G25-AV513 Notebook
Toshiba qosmio G35 AV600 refurbished laptop
if you have the CD driver for your laptop (audio driver) try reinstalling it.
Oct 30, 2007 | Lenovo 3000 C200 Notebook
Toshiba Qosmio G25-AV513 Notebook Logo
284 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
