Question about Maytag MAV7200 Top Load Washer
Loud noise -- water pump??
Maytag mav7257 aww. It started smelling like burnt rubber then shut down and wouldn't come back on. I waited a couple of hours and now it runs ok but there's a loud grinding noise. I checked the belt and although it's still intact I can see where it was burning. I turned it on without the belt and the motor ran without any noise. I turned the pulley for the water pump by hand (without the belt on) and it sounds awful noise and turns like it's grinding. It also catches sometimes and I have to give it a good turn to free it. I think I need another water pump. What say you? Also how much does one cost?
  • mwestmorel Nov 25, 2007
    Thanks for the quick response. I kinda thought that might be it. I was just wondering if that was a common thing to happen so thanks for the input.
  • 447 Answers
Yes you definately need a new pump assembly part number 21001906 $59.95. That is a maytag part number and it is a very common repair. The new pump is a revised design and will look different but will mount the same. Axcess through front panel.
Posted on Nov 25, 2007
My car is hard to turn, it makes an awful noise and is smoking, it smells like burnt rubber, if i continue to drive it what will happen
Hi Debbie,
Not sure with out looking at it, But from what you posted if hard to turn
sounds like your power steering punp aint working , ant if smoking and smells like burnt rubber sounds like pumps locked up, (pully not turning) and if so continuing to drive it could leave you on side of road if it runs a cerpintine belt , that kind of belt runs every thing and if breaks water pump stops flowing water motor will over heat, you should realy have someone look at that for you.
Feb 05, 2014 | Dodge Cars & Trucks
When i turn the wheel my car makes a loud noise and smokes, it smells like burnt rubber, is it safe to drive it
Sounds like the power steering pump is locking up and the belt is slipping. Get it checked out before you drive it.
Honda passport problem
The louder noise and burnt smell possibly was the bearing getting worse, or going out, causing the belt to slip over the pullet and start heating up.
Was it a burnt rubber smell?
I don't see how this could have anything to do with the flywheel though.
Dec 18, 2013 | Cars & Trucks
Loud noises
your torque converter could have went. i feel its definetly your trans. i need more input
Dec 15, 2009 | 1987 Chevrolet Blazer
Washer stopped at begin of wash cycle
The problem seems to lie in the rubber backed mat. If the rubber has begun to peel of the mat it often-times get stuck in the drain pump. The best thing to do at this point is to disconnect the electrical cord, open up the machine, drain out the water as best as possible disconnect the power cord to the drain and the hoses. Clean out the drain pump. reassemble. You should be good to go., Unless the drain pump is burned out (left running plugged up too long) if thats the case, replacement of the pump may be neccessary.... Hope this helps...Good luck!.... Bill
May 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
WASHER STARTS MAKING LOUD NOISES WHEN SPINNING SOUNDS LIKE IT IS OFF BALANCE BUT NOT. ALSO FAINT SMELL OF BURNT RUBBER.
The washing machine will do this if the load is unbalanced. Usually due to either an excessively heavy and/or large load. The burning rubber smell is just the drive belt dealing with the imbalance. Often the washing machine will self-balance itself, but it's a good idea to open the lid and re-distribute the load. Or remove some stuff if it seems too heavy.
Sep 06, 2008 | Maytag Washing Machines
Maytag MAV7200 Top Load Washer Logo
201 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
