Question about Samsung SyncMaster 245BW Monitor
Syncmaster 245bw monitor resolution screen and resolution issues
When i display this monitor in 1920 by 1200 resolution it cuts off about 5 inches of the screen and the only way to see the far left or right of the screen is to scroll the mouse to the far left or right. i just updated my nvidia geforce fx5600 xt to the latest drivers and that did nothing. Also when i hook my xbox 360 up to the monitor it can only be displayed in 640 by 480 resolution. If i change the display resolution on the xbox the screen blows up and i can only see the middle of the screen. kinda like if you're using a high resolution on a computer and uninstall your video drivers everything gets HUGE.
  • Frostrazor Nov 26, 2007
    what 2 devices are not compatible? the xbox and the monitor? if so why not? a few friends of mine use their computer monitor and their xbox this way.
    also what would cause the "scroll" to happen when i use the monitor with my computer?
I have tried all my res settings and can still scroll off the screen to the right even on 800 by 640 , monitor says its 50/50 so it should be centered anyone know how to fix this
Posted on Mar 08, 2008
    Scholar:
  • 116 Answers
These two devices are not compatible, you may need to read the information on this LCD MONITOR to see if the resolutions are compatible, this often times happen when monitors are purchased!
Posted on Nov 26, 2007
  • Herman Briggs
    Herman Briggs Nov 27, 2007
    Resolution changes cause your scroll to occurr, this happens when a monitors resolution is set too high. The best way to figure this one out is to work with the resolution.
    Test the theory:
    Right click on desktop
    Select properties
    Tab over to settings
    there is a bar in the left bottom corner
    Screen resolution
    Less starting at 800 by 600
    More ending 2048 by 1536
    these settings vary based on drivers installed and graphics card
    When you select one of that suits your needs
    Select Apply
    Your screen will flicker and you will be given a preview of what your screen will look like with the selection you have chosen
    Continue to play around with this until you have found the appropriate setting!
  • Herman Briggs
    Herman Briggs Nov 29, 2007
    This fix was a good attempt! Thanks for the bad rating! I believe I have to go back and look up inappropriate!
Samsung 245BW No Display
have you tried this monitor on another computer? what was the result? Also, try laying the monitor down flat and see if you see any "ghosting" from the characters on the screen. (if the backlight goes out on the monitor, you should be able to see some of the graphics displayed on the screen still with a flashlight or at an angle if the monitor is working)
let me know what you find out
Jun 09, 2012 | Samsung SyncMaster 245BW Monitor
Samsung syncmaster 245bw powers on but there is no display.
check your rgb chord found at the back of your monitor, i think it is color blue chord that connects through cpu and monitor..push it tight and it will display again..
i hope it can help you
Jul 25, 2011 | Samsung SyncMaster 245BW Monitor
Plug in the monitor and it comes on momentarily but then cuts out to blank screen.I got this given to me and am just trying to see if Ican use it with my hp system thanks.
Hi. If the display goes out after displaying the Power On Self-Test (POS) and the power indicator turns amber, it means that the display resolution of your computer is higher than what SyncMaster 192S can handle.
If you still have the monitor that you were using before, connect that one and change screen resolution to 800x600 and 60 Hertz. Turn off your computer then change monitor/LCD and turn on your computer. You may change screen resolution to optimize display on your SyncMaster 193S.
Let me know if you need help changing screen resolution or if you don't have the original monitor that you were using on your HP.
Aug 18, 2010 | Samsung SyncMaster 193S
Monitor don't work with my CPU
first check your system resolutions on settings of display settings. what is the resolution of screen. and check monitor supported resultion information is there on monitor manual. adjust display resolution if necessary. then connect new monitor.
First you check whether the new monitor displays your system starting screen. mean before booting into windows. some text in black color.
Jun 22, 2010 | Samsung SyncMaster 743B 17 inch LCD...
Samsung syncmaster 245bw menu buttons don't work
It is a hardware problem. you can repaired it from service center.
Nov 13, 2009 | Samsung SyncMaster 245BW Monitor
How i can fix my 21.5" computer samsung monitor, the display is slightly stretched
Set your screen resolution to 1600 x 1200, the native resolution of the screen.
Oct 11, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Reload
I'd say your video card is having trouble pushing the resolution of the monitor. I'd upgrade the video card.
Sep 10, 2008 | Samsung SyncMaster 245BW Monitor
Monitor will not display in native resolution.
sounds to me like they replaced your vga board with another compatible one but not the same exact one I would call the repair facility that did the work and ask questions about how they repaired the monitor like if they used another vga board etc. hope this helps
Jun 19, 2008 | Samsung SyncMaster 245BW Monitor
Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Samir
Jun 13, 2008 | Samsung SyncMaster 510N (Silver) 15 inch...
Samsung Syncmaster 245BW sync problem
If you are plugged into a NVIDIA graphics card, use the NVIDIA control panel scaling option to "do not scale" then set the resolution to 1920x1080. This monitor is a 16:10 aspect ratio instead of 16:9 like HD TV's, so it is necessary to turn of scaling from the software and thus give black bars.
Aug 10, 2007 | Samsung SyncMaster 245BW Monitor
Samsung SyncMaster 245BW Monitor Logo
235 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
