Fisher and Paykel Fisher&Paykel Laundry: Fisher&Paykel Washer
Problem for Fisher and Paykel Fisher&Paykel Laundry: Fisher&Paykel...
Fisher and Paykel GW708F Screaming like a jet engine on spin!
By andyliv2xs on Aug 03, 2009
Fisher and Paykel Frigidaire Excellence Model GW708F. Screams like a jet engine powering up when in spin cycle. Is it a bearing or a pump or what? No other problems. Noise only comes on spin, when it's pumping out the water sounds normal.
Comments:
Aug 06, 2009
- Yup it did help, as in it's no longer noisey! I replaced the bearings for $40 myself but I think I've made a mistake somewhere. Put it all back together. I put nothing in and it filled and emptied fine. So I put clothes in and ran a hot wash and it fills, stops, fills, stops... like it's jogging. I jiggled the bowl and gave it a bump and it washed, but when it got to the rinse cycle got the same jogging. Lights come up 10000011 (0 off 1 on) on the display when it beeps. Any advice other than I should go to appliance repair school?
Best Solution
posted on Aug 04, 2009
Helpful)
speirse
Rank: Master
Rating: 99%, 8 votes
Hi there
Yea if the machine sounds like a train going through the middle of your house when its on spin it will most definately by your seals and bearings, an easy way to check is lean the machine back onto something and look underneath if the main seal is leaking and the bearings are run there will be rusty looking residue on the motor rotor(the round thing in the middle of the drum), seals and bearings are fairly expensive to replace About $350NZD if no shaft is needed and up to $500NZD if a replacement shaft is needed.
I hope this helps you out.
Nick
Comments:
Aug 17, 2009
- Did you replace the seal as well? for the fault code thats repititive rotor position sensor error, thats the wee green board that slides into the side of the motor these commonly fail when the seal has been letting water through, check wiring and plug and if that doesnt sort it replace it, also failing that it could be your motor controller.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Fisher and Paykel
Questions and Unsolved Problems for Fisher and Paykel
Do you recommend Fisher and Paykel Fisher&Paykel Laundry: Fisher&Paykel Washer?
Answer
Answer
My Fisher and Paykel washing machine smart drive 608 won't switch on
Answer
Hi, I have a 601 model its about 14 yrs old, love it but now My hot and cold water are both... (More)
Answer
I have a fisher and paykel 601 smartdrive, it will not start, no lights come on, have spare parts... (More)
Answer
hi,i have 5.5 smartdrive 9 excellence washing machine,it was alright,until i was about to start the... (More)
Answer
F & P Smartdrive 708 has all lights showing when powering on, but will not start wash cycle.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fisher and Paykel...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
