Https://www.shopyourway.com/questions/1040579
Quoting from link shown:
What does F23 error code message mean on Kenmore Elite built-in double ovens?
Report This
by Manage My Life
August 17th, 2009
What does F23 error code message mean on Kenmore Elite built-in double ovens? The model number is 790.48143800.
: What does F23 error code message mean on Kenmore Elite built-in double ovens?
Resolution
: Error code
F 23
indicates the control detected a problem with the communication link or can be generated as a result of irregularities in the power supply or usage.
The error code
F23
can often be resolved by removing power to the appliance for a minute and then restoring the power.
By unplugging the appliance it allows the control to receive a fresh supply of power. This in turn will clear the controls memory of any irregularities it may have received from the power supply. Once refreshed the error should no longer be displayed.
Unplug the unit or turn the circuit breaker off for 60 seconds.
Restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
Check to see if the error code is still displayed on the range.
Run the appliance in the cycle that initially caused the error or attempt to turn on broiler.
If the error code is displayed, then service is needed.
Note
: General resolution for problem is based on information submitted with question. If problem persist, contact a service technician to
Sears Repair Department 1-800-469-4663
SOURCE: F90 Err on Kenmore Elite
the F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Good Luck
SOURCE: Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
SOURCE: Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
SOURCE: Error message F44 in a Kenmore Elite Dryer. What
F-44 indicates a faulty blower motor controller. $169.00 from sears
or about $115.00 from an appliance parts store. Also note: the
service technicians repair guide is usually folded and tucked inside the top of the dryer console. It contains all the F codes and disassemble and reassemble and testing instructions. Part # for the service guide is (W10035270).
SOURCE: my kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Hi
Error
code F1 means that an error with the keypad has occurred. Usually it happens
due to loose ribbon cable on the keypad or the electronic control assembly
itself going bad. To resolve this issue first, disconnect the power to unit and
then gain access to the back of the clock assembly (Electronic Range
Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would
be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable
is not broken and nothing is shorted on the keypad. After this is done insert
the cable back and then plug the unit back to check. If the error is still
there then the electronic control board should be replaced. Hope
this helps...please post back for further assistance.
Daniel
