Question about PC Laptops
Samsung g600 every time i try to connect my phone to pc i get a message on the add new hardware wizard telling me it cannot add it as data is invalid
  • 145 Answers
Re: samsung g600
Try using the phone software that came with the phone, or try downloading it from the phone manufacturers site.
Posted on Feb 11, 2008
0 characters
3 Points
Bluetooth connection issues
There are several things to try:
Remove and then reinstall the device:
Click the Start Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
Select the device that's not working, and then click Remove.
Click Add, press the reset button on the device
(or make it discoverable following the manufacturer's instructions), select the My device is set up and ready to be found check box, and then click Next.
If the device is not found, repeat the previous step.
When the device is found, select it, and then click Next.
Follow the rest of the instructions in the wizard.
Make sure the device is turned on and that the batteries don't need to be replaced.
Make sure the Bluetooth adapter for your computer is attached and turned on, and that the device is turned on and discoverable.
If you're not sure how to turn on discoverability, read the instructions that came with the device or check the manufacturer's website.
Make sure that you installed the device using the correct program. If not, reinstall the device.
For a printer, follow these steps:
Open the Add Printer wizard by clicking the Start Control Panel, clicking Hardware and Sound, clicking Printers, and then clicking Add a printer.
For a mobile phone, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Click Add.
For a keyboard or mouse, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Connect a wired keyboard or mouse to your computer.
Click Add.
The device might be out of range of your computer, or too close.
Try moving it closer or a little farther from your computer.
hope this helps
Runs in the background, and monitors the activity of Bluetooth devices around you
Oct 06, 2012 | HP Pavilion dv8000z Notebook
My laptop says it has an invalid ip address
If the laptop's own IP address is invalid, you need to figure out where the incorrect settings are. If you're running it with a wireless adapter and a router, make sure that the network connection is set to DHCP and not to static IP address.
Probably the best course of action, especially if you're not very experienced with networks or IP addresses, is to run the New Connection Wizard, which you can access like this:
1) click on Start
2) move the mouse pointer up to Settings
3) click on Control Panel
4) double click on Network Connections
5) click on File
6) click on New Connection
7) follow the instructions.
I hope that helps! Good luck.
Oct 10, 2010 | Samsung PC Laptops
Error message of "Unable to detect fingerprint device"
Go to control panel from start menu,then click icon "add hardware".
Follow the instructions, click yes when asked about device is connected,then choose something like"human interface device", keep following the procedure until you find the hardware that match with windows.
Hope it works!!!
Dec 10, 2009 | Acer TravelMate 5720-6635 Notebook
No instruction on line for installing new nano receiver
Your nano receiver should be detected by your new hardware wizard. Try using the add hardware wizard.
Oct 21, 2009 | Gateway PC Laptops
Whentrying to installed any new hardware.PC wont work new items
Mar 28, 2009 | Acer Aspire 5101WLMi Notebook
Wharfedale MP3 player won't install to IBM Thinkpad
Feb 12, 2009 | IBM ThinkPad T40 2373 Notebook
Error code 37
Hi there
The Code 37 error may occur when the concerned device is not connected to the system correctly and when its driver is faulty. A code 10 error is common when you add or remove USB devices or video & sound cards to and from your PC. When these errors occur, you may receive the error message given below.
Windows cannot initialize the device driver for this hardware. (Code 37)
To resolve code 37 errors, first ensure that your device is properly connected to your system. For instance, check all the cables of your printer or check that your sound or video adaptor is properly seated in its slot.
Try to remove and reinstall the device, and run the Add New Hardware Wizard from the Control Panel to see if Windows detects and installs it. If this does not resolve the issue, then update the device driver by performing the following steps:
  1. Open Control Panel and select System.
  2. In the System Properties dialog box, select Hardware tab, and then click on the Device Manager tab.
  3. Scroll down the Device Manager window and identify the faulty hardware from the list.
  4. Right-click on the hardware and select Update Driver.
  5. Follow the screen instructions to resolve the error.
If these steps do not resolve your error, then the problem might be with your device. Get it checked by an authorized technician.
Good luck
Jan 14, 2009 | PC Laptops
USB Hardware Installation Problem
Try the following:
To fix the Error 13: Data is invalid problem, go to Start, Run... and type "REGEDT32.EXE" without the quotes to run the Registry Editor. Navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ENUM\PCI and you will see a number of keys of the form "VEN_xxxx", where xxxx are strings like "1102&DEV_0004&SUBSYS_00011103&REV_04".
Under each of these folders will be another folder with a long numerical name.
Open each folder and look for the "DeviceDesc" which matches the hardware you are trying to install.
HIGHLIGHT THE ENTRY "VEN_xxxx" for that device and select 'SECURITY'-'PERMISSIONS' FROM THE WINDOW TOP MENU and then tick "Allow" for "Full Control".
Close REGEDT32 and then continue with the installation of your device.
This wil lremove the Error 13: Data is invalid from your wnidows 2000 / 2K / XP system. Repeat this for each hardware device you get the Error 13: Data is invalid problem with.
Jan 14, 2009 | Dell Inspiron 6400 Notebook
Mouse and key board are frozen
I have been a pc specialist for 14 years,and have seen this problem many times! sometimes there is a work around, most times the motherboard is damaged! you could try to find a used motherboard but may be no better off! you must weigh the cost of repair and used parts against the cost of a new notebook! I believe this to be a chipset failure.try removing memory modules and re-installing same.or try other modules if available.good luck!glen!
Jun 06, 2008 | Acer Aspire 5100 Notebook
PC Laptops Logo
21 people viewed this question
Top PC Laptops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Laptop Expert? Answer questions, earn points and help others
