SOURCE: CD WONT PLAY
It sounds like it is attempting to read the t.o.c. (table of contents) which tell the unit where everything is on the cd,and failing to do so, then ejecting, the first thing to do is try cleaning the lens and if there is no change then replace the laser pickup
SOURCE: CD won't work
Have you tried using the reset button on the front of the unit (under the face panel)
SOURCE: car stereo won't eject discs as 2 cd's now stuck in it
if you can get the radio out of the car, you may be able to take the top off and get the cd's out that way.
SOURCE: cd stuck in my in dash player in my car
recently had this problem, take two credit cards or id, and use them as tweezers to pull out cd(s). It works better, faster, and does little to none scratches on your cd(s).
SOURCE: CD/DVD for Eonon E0852
Easy fix, replace the infrared sensors on the mainboard of the unit. I tried to get support from eonon & they were not interested at all. The sensors you can pick up from jaycar, **** smith electronics etc. You will have to align the sensors once you have soldered them in. Hope this helps, it worked for me.
