Garden Logo
M
Mark duarte Posted on Sep 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just bought a champion 35 petrol lawnmower is it 2 or 4 stroke as cannot find anywhere to put oil?
Pieter Vleeshouwers
Level 3:
  • Master 2,029 Answers
  • Posted on Sep 07, 2018
Pieter Vleeshouwers
Master
Level 3:
Answers
2029
Questions
0
Helped
4112498
Points
7389
4 stroke better find out where you have bought the reseller and or even look here on youtube are several options and for a service manual
Briggs And Stratton Service Manual Free
5 Related Answers
Anonymous
  • Posted on Mar 29, 2009
SOURCE: where do i put 2 stroke oil? do i mix with petrol
its under the front of the tank take the seat off undo the allen bolt at the front right side of the tank and lift the front of the tank up there is a support rod under the tank to hold the tank up
Anonymous
  • 2559 Answers
  • Posted on Apr 04, 2009
SOURCE: JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Anonymous
  • 207 Answers
  • Posted on Jul 09, 2009
SOURCE: oil to petrol for 5.litre can
the fuel to gas ratio should be 50;1 50 parts oil to 1 part fuel
Anonymous
  • 2468 Answers
  • Posted on Apr 14, 2010
SOURCE: CHAMPION VANTAGE 35 PETROL LAWN MOWER
the recoil dawgs in the cover housing are either shot or not engaging into the top starter cone
Anonymous
  • 252 Answers
  • Posted on Sep 12, 2010
SOURCE: What mix of 2 stroke oil do I use for a Stihl
if using top quality 2 stroke oil
you put 100 mils of oil into 5 litre container and add 5 litres of fuel only that is 50:1 petrol oil ratio
cheers pauly46
1helpful
2answers
I have just bought a petrol hedge trimmer model hht 2660 with no manual I need to put some petrol in but am unsure if it’s 2 stroke or straight petrol can you please help ?
Almost all are 2 stroke. If it has a place for oil togo into the motor-like a dipstick, it’s 4 stroke. If there’s no place for engine oil, you mix your petrol with 2stroke oil. Haven’t heard the term petrol in a while!
Sep 22, 2020 • Garden
1helpful
JCB M25 strimmer, bought second hand does anyone know the fuel mix ratio please ?
TO MIX THE FUELSee Figure 3.? The product is powered by a 2-stroke engine and requires pre-mixing petrol with2-stroke oil. Pre-mix unleaded petrol and 2-stroke engine oil in a clean containerapproved for petrol.? The engine is certified to operate on unleaded petrol intended for automotive usewith an octane rating of 91 ([R+M]/2) or higher.? Do not use any type of pre-mixed petrol/oil from fuel service stations, such asthe pre-mixed petrol/oil intended for use in mopeds, motorcycles, etc. Do not useautomotive oil or 2-stroke outboard oil.? Use only synthetic 2-stroke oil.? Mix 2% of synthetic 2-stroke oil into the petrol. This is a 50:1 ratio
Feb 12, 2019 • Garden
1helpful
Bought it at local, start alright with petrol. When try with 2 Stroke RYOBI Synthetic Oil hard to start. Should i just use normal petrol oil?
no --- 2 strokes use a special 2 stroke oil ==not ordinary engine oil==
the difference is that the 2 stroke oil is specially blended to mix with petrol and will not block up the fine jets in the carby
it also "sticks " more readily to the metal components in the engine thus preventing wear
as a point of interest most small engines do not like E mix fuels either
so for trouble free operation --2 stroke oil mixed in the correct ratio with either 89 or 91 octane petrol and it will start first pull every time
use the primer bulb sparingly or the choke until it fores
TYPE PETROLE AND OLE USED IN 2 STROKE LAWNMOWERS
boat gas works best any of the new 2 stroke oils work well
1helpful
Champion 35 lawnmower hunts
Clean the air filter (foam type) in warm soap water then apply some oil soaked in, it will smoke afterwards for a short time. Or possible minor adjustment too the mixture screw on the side of the carburetor spring loaded. Allan
May 09, 2012 • Garden
2answers
What sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Judging from what discription you are giving me I would say it is a 4 stroke, so make sure you have either sae 30 or 10/w30 oil in crankcase where it says oil and petrol (gas) in the other tank. 2StrokeJim
Oct 27, 2011 • Garden
What oil do i put in my sovereign 35 classic
you have to put motor oil in 4 strokes basicly all lawnmowers have 4 strokes
Aug 17, 2011 • Garden
I have a Poulan 625 push mower. What type of oil should I use in it? I can't find my manual.
If it has a 4 stroke engine, as most lawnmowers do, then you just car engine oil. Very occasionally you come across 2 stroke mowers.
The way to know if it's a 4 stroke or 2 stroke engine is, if it has an oil tank it's a 4 stroke engine. If there's only the one tank, i.e. you mix the oil with the petrol then it's a 2 stroke engine.
If it's a 2 stroke engine you mix petrol and 2 stroke oil at a ratio of 40:1
1helpful
Horse Power: 3.5 hp
Apr 04, 2009 • Garden
1helpful
Need to know the correct levels of oils in a chainsaw
Most McCulloch saws use a 40:1 oil ratio if using McCulloch branded 2-stroke oil. They state 20:1 for other oils, but this is probably overkill as most name branded 2-stroke oils these days are pretty good. I would probably go for a 30:1 or 35:1 mix to err on the side of caution. This will not affect performance, it may just mean you need to change spark plugs a little earlier than usual, but the cylinders will at least be well lubricated.
Please rate my response on FixYa.
Top Garden Experts
Jay Finke
Jay Finke
john h
