Question about Hotpoint Ultima WF860 Front Load Washer
All lamps flashing and display flashing 888
When I switch the machine on all lamps and centre display flash continuously. Eventually this will stop and I am able to set the machine. Is this a fault warning?
  • 3,917 Answers
You board behind the control panel is blown. This is caused by either a faulty door switch or the motor. Your model number tells me it’s most likely the door switch. The control board will need replacing and the door switch.
Getting to the board is easy only three screws near the soap draw. Make sure you write which wires go where and to get to the door lock undue the door rubber
Thank you for contacting Fixya.com
Posted on Aug 03, 2009
SOURCE:
Optoma HD80 flashing blue lights
Sound like the original color wheel for Optoma HD80 is bad.
If the unit has been moved when hot.
If not, try un-plugging the unit for a few minutes and re-connect.
Hope this helps
Mar 23, 2014 | Optoma HD80 Projector
Sony KDS-60A2000 - no sound.
If you are lucky, a new lamp will restore the sound as well otherwise you may require a new ballast unit as when the lamps explode, the supply board sometimes destroys itself.
Mar 19, 2014 | Sony KDS-60A2000 60" HDTV
Above mentioned tv suddenly stopped showing pics or audio, and now it flashes red light 3 times every times it is switched on. Sony service centre person is asking to change the lamp but is unsure abo
If its both audio and video then it has something to do with the power unit, ask the service centre technician to test the ICs because some may have been burnt, before looking at the lamp.
Oct 19, 2012 | Sony Kdf-e50a10 50-inch Lcd Rear...
My whirlpool duet is displaying the error code 888. It works ine through all cycles but the time displays 888. All the lights are illuminated and there is a high pitch alarm sound that remains on until...
Please state brand and model of your washing machine for accurate and specific solution...
There is no 888 error code on my list of whirlpool..I think the 888 flashes is the time remaining..
If the lid opens while the unit is in running mode, time remaining will flash in the display.
Close the lid and press START to continue with the cycle.
Hope it helps..
Dec 03, 2011 | Washing Machines
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
Jul 17, 2010 | AEG B2100-4 Electric Single Oven
MY ALARM ON MY MP210 IS ON AN MY COLOR INK FLASHES WHAT DO I DO
Check the status of each cartride by using the ink lamp.
You have 3 lamps
(A) Alarm lamp
(B) Black ink lamp
(C) Color ink lamp
Make sure that the LED is on standby mode.
a) If the ink lamp lights.
Cause : Ink is low.
Action :You can continue printing for a while, but we recommend you have a new FINE cartridge available.
b) The Alarm Lamp lights and the ink lamp flashes .
* If "E, 1, 3 " is displayed on the LED, ink has run out.
Cause : Ink level cannot be detected.
Action : Ink may have run out.
The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected.
If you want to continue printing without this function, press Stop/Resset buttonfor atleast 5 seconds.
Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities.
* If E,1, 6" is displayed on the LED,
Cause : Ink has run out.
Action. Rreplace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress, you want to continue printing, press the Stop/Reset button for atleast 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
c) Only the ink lamp flashes
Cause : The function for detecting the remaining in level is disabled.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Light keeps flashing and water will not heat
there is a float at the side of the machine by the water level, if the float gets stuck the red light will continue to flash even though water is present. Use a magnet on the outside of the machine by the water and float level and raise the float when connected to the magnet and the light will stop flashing red rapidly
Oct 05, 2009 | Philips Senseo HD7832 Coffee Maker
4x4 light is flashing (TOD indicator)
this means there is a problem if it continuosly flashes
Short-circuit terminal 8 of the self-diagnostic
connector to GND to display the trouble code on the
CHECK lamp.
If no trouble codes exist, code “12” is displayed continuously.
If trouble codes exist, code “12” is displayed three times, and then other trouble codes, starting from the smaller code number, these are displayed three times respectively.
this is located behind right front centre console side trim..
Jun 30, 2009 | 2001 Isuzu Trooper
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
165 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
