Back to:
Tags:
Haier BC112G Wine Cooler
Haier wine cooler (by 3 users)
posted by mkmae5 on Nov 25, 2007
I bought this used and do not have the owner's manual. How do I set the temps for the wine?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by springcheer, posted on Mar 25, 2008
I have the same problem (this unit was left to me in my uncle's will... no manual to be found), but I believe my fridge has a temp setting for white and red wines. How do I set each? Also, which temp is displayed in the single temperature window (white or red)? Thanks for your help. I don't want to ruin my wine!
Comment by andre1234, posted on Nov 30, 2007
lost the intruction manual and would like to know how to raise or lower temperature in the BC112G wine cooler
Best Solution
posted on Mar 18, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hold + and - keys down together until LED blinds (about 4 or 5 seconds), Then press + or - key to lower or raise temp. Once you've reached the desired temp press the set key.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on haier wine cooler:
I don't want to Accept this solution
Solution #2
posted on Sep 13, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
See Manual at http://www.haieramerica.com/en/asset/archived/BC112G.pdf
Thank You!
Solution #3
posted on Jul 07, 2008
Not Rated (0)
mcpniz
Rating: 0%, 0 votes
Thanks, I set the temp higher and I'm waiting to see if it actually goes up or keeps getting colder . I have notice that the red light that was lighted before is out and now the green light is on . Not sure what that means but usually green lights are better that Red !!!
Thank You!
Can you Help with these Refrigerators problems?
LL shows on led and is not on list
The top fan on the thermoelectric fins on the cooler...
All of the sudden, the temperature rose to 91F and when I...
Door seal has a gap of apprx 1/4 " on top left corner...
Our 32 bottle Haier wine cooler makes a...
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
