Question about GPS Devices
Manuel for Walkie Talkie
MODEL NO. GMRS-2572CH CATALOG #: 55026050
Re: Manuel for Walkie Talkie
How do i master reset my garmin street piolot c550?
Posted on Dec 14, 2007
  • 25 Answers
Try here
Posted on Nov 26, 2007
0 characters
3 Points
Can it be updated?
Hi Jimann2771,
I've checked on this before with several companies, including Audiovox and Clarion. Audiovox came out with this in 2006, and your maps maps may be as old as 2005. Audiovox has not issued or supported newer maps on this model since then to best of my knowledge. That's not too say the least. I finally found updates for mine, but it was through other sources, and took a little programming.
Anyway, in case you don't have it, here's a link to the manual for your unit:
Check around and see if you come up with anything. If you don't, check back and I'll do some more research to see if we can get you something more updated.
Regards, Bill
Sep 18, 2010 | Audiovox NVX226 GPS Receiver
Map updates
This is what I got back from Jensen/Audiovox:
"I am sorry, but this product line has been discontinued and there are will be no updates issued for the mapping software. Audiovox will continue to support these units for service and repair issues. I apologize for any disappointment this may have caused.
Trudy, Customer Service"
I will never again purchase an Audiovox/Jensen pieve of ****!
Apr 11, 2009 | Audiovox NVX-200 Car GPS Receiver
I have Binatone two way radio MR 250. My son
1st. try removing the SD card and see if that works.
2nd. try to do a hard reset on the back of the unit using a ballpen to see if it works.
Lastly would be to check out these sites:
Mar 31, 2009 | Toymax Binatone Carrera X350 Car GPS...
Dual xnav3550
easy one read opt volt on cherger if o or low replace with same voltag current output local radio shack nice one 15 25$ if u would like info on how to repair charger it self will give info 2 do that just ask normally the transformers burnout it cheaper 2 buy new than rebuild
Dec 08, 2008 | Dual Electronics XNAV3550 Car GPS Receiver
I did not get a owners manuel in my jensen navigator
If your unit is a JENSEN NVX200 GPS System, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 01, 2008 | Audiovox GPS Devices
Can you please assist me with a site to download upgrades for my gps Audiovox NVX227SA.
The Maps loaded on the device are old.
Aug 19, 2008 | Audiovox NVX226 GPS Receiver
Fatal error, unable to open application database
Have you tried the reset button? It would be found on the lower right side on the rear panel. Don't really know if this will fix your particular problem, but it might be worth a shot.
Dec 13, 2007 | Audiovox NVX226 GPS Receiver
Need replacement car power cord for NVX226 GPS
I bought a car charger for a motorola razr for ten bucks at a gas station and it works perfectly. i also bought a replacement cord from radio shack which also worked perfectly but hit me for 24 bucks. Either or is fine!
Oct 22, 2007 | Audiovox NVX226 GPS Receiver
GPS Devices Logo
127 people viewed this question
Top GPS Devices Experts
Are you a GPS Device Expert? Answer questions, earn points and help others
