Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Top Load Washer MAV6000
I have a Maytag Top Load Washer that will not automatically spin and empty out the water, and sometimes if will not agitate in the rinse cycle. However, if I hold up on the knob it will work. I have replaced the knob and the spring, and I still have the same problem. Thanks for your help.
  • 213 Answers
In the console behind the knob is the timer. there are several contacts inside the timer that tell it what to do. one of thoughs contacts is bad. you need to replace the timer to fix the problem
Posted on Nov 25, 2007
I have a Maytag Atlantis MAV6200AWW Washer agitates and spins. Water sometimes empties. Pump is fine spins freely and the impeller is fine. Could it be the belt ?
You will need to check for an article of clothing stuck between the basket and tub that may be partially blocking the drain hole.
Nov 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer mav6300aww drains water but does not spin
my maytag washer model #MAV6300AWW will not spin out during cycle but can turn it back to spin and will spin out
May 30, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Wont spin
If it's NOT a direct drive machine, then your problem is most likely with the Wig-Wag switch, located on top of the gear case! It ALWAYS goes bad and effects the Spin function.
Aug 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Have a Maytag washing machine MAV7600AWW.
sometime not always it wont spin also the water temp is more on the cold side
Aug 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Motor will not spin both ways
Starts fine then stalls, I would check the belt,gear case and also for a seized pump bearing. Pull the machine out and remove the access panel with a 5/16 socket and put it into spin, try to watch as you start the cycle. Then if you don't see any problems tilt the machine back and examine the belt for wear, glazing, cracks and rotate the belt to find any frozen items, gear case and pump.
Oct 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top load won't drain
during spin is the tub making a slight roaring sound? if so the tub bearing is going bad causing the motor to work harder than normal causing it to heat up. this motor has a thermal protector which shuts it down , although the power to the timer remains therefore the timer still advances. this will require a new bearing and seal kit.
Feb 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
117 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
