Question about Archos Jukebox Studio 20 MP3 Player
Studio 20 i have a studio 20 but wheb its connected to the computer through the usb i can see the new drive letter but cannot ecces it at all i get device not accessable i/o error
  • wercampbells Oct 13, 2008
    I have a similar problem. I CANNOT SEE the drive AND when I power on the player I get the message Jukebox Wait..." then I receive the message "File sys. error". Please help. Thanks!
Me too but I dont use my archos what will ı do
Posted on Dec 06, 2008
Wont read anymore or do anything!
large hard drives dont like being swapped around to different computers and there operating systems they are not good swingers
try connecting the drive directly to a port on the computer.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
Also check if it's detected in "Disk Management".
Here you can verify if the partition and format are correct for the Operating System.
Check the Drive's status in Device manager.
This will verify if the external drive has a drive letter designation.
Check Partition and Format.
Log in as Administrator account in windows or any other account with administrative privileges
Insert your removable disk into the USB port.
Click Start, right click on computer and select manage.
Now, click Disk Management.
Check whether drive letter for the device is present.
Check the lower window to find whether the device is detected (such as Disk 1, Disk 2, etc).
If the device is detected with a drive letter, verify that no other device is using that drive letter.
If it is, change it to unused drive letter.
hope this helps
Sep 19, 2012 | Hitachi Touro Desk 1 TB USB 20 External...
I ahve an 8gb Ultra speed USB drive and my computer will not recognize the USB it says please insert disk in drive
From the Computer Management panel, select Disk Management from the left hand panel. Once Disk Management has been selected the right hand panel of the Computer Management window will display the drives connected to your computer. In the bottom half of this window, scroll through the list of drives that are on your computer system. USB drives will fall under a category of USB mass storage device. Right click on the label for the USB drive and select the option to Change Drive Letter. Select Change from the new window that appears and select a new drive letter for your USB drive. After applying the changes, your USB drive should be automatically recognized by your computer and assigned the new drive letter.
Apr 10, 2012 | Transcend Computers & Internet
How do i download the instructions on how to use this product
i am not sure if there are any instuctions with such a device.
a usb hardrive is a what is called a plug and play device.
this is a data portable transfer device once connected to a PC for example it will act like an extra hard drive or HDD. when you connect it using a usb cable it should be found automatically. and will show up on your pc as a new drive letter.
example you have drive C: as your main hard drive.
when this hard drive is connected it will show up with a new letter such as D: or anoter letter.
and when you right click it you can check the properties to see how much capacity it has.
you can and a remove files to it in the same you can your normal hard drive the advantage is you can remove it while the pc is still running and move it to another device such as other pc, dvd player etc and play or move data around. when you want to remove the data from the drive you can connected it to a pc and find the files and delete them or even format the whole drive if you wish.
i hope this was useful.
Jan 05, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
Seems to have hidden itself when I connect to
the best way to find a removable storage device is to Right Click on Computer and select manage. After the computer management screen opens select and expand storage. Select Disk Management. You will see any device and the drive letter it is associated that is connected to your machine. Sometimes a device wants to use the same drive letter that is already in use. Most common when you have network drives mapped or recently added additional drives.
If you still can not access your USB but see it in the drives then you may need to change or set the letter. To do this right click on the drive and select change drive letter and path. You can select any available letter from d-z
Jan 18, 2010 | HP Compaq 6710b Notebook
Western Digital External HDD not appearing in My Computer
It could be that the OS is not assigning a drive letter to your removable drive. To do this, go to disk management and assign one.
Assuming OS is Win 2000/XP/Vista
Right-click My Computer then Manage
Click on Disk Management
Right-click the removable drive and click on Change Drive Letter
Assign a drive letter and click OK
Your drive should now show up on My Computer
Hope this helps.
Jun 20, 2009 | Western Digital Passport 320GB External...
Cannot see drive letter for deskstar 7k250 in usb enclosure winxp
Add a letter for this HDD in "control panel\performance and maintenance\administrator tools\computer manager=ment\disk management"
Feb 16, 2009 | Hitachi DeskstarĀ® T7K250 250 GB Hard Drive
How do I transfer pics from my computer to digital frame sv811
Connect the frame to you computer via the USB cable. Your computer should see the frame as a removeable storage device (new drive letter) if there's memory on the frame to store images. If not, then get a cheap memory card or USB key for $20 and put the images there.
Jan 11, 2009 | Kodak EasyShare SV811 (8858946) Digital...
ME-940 usb enclosure not reconized
This behavior occurs if you map a network drive to the first available drive letter after the drive letters for the local volumes and CD-ROM drives. When you install a new device or volume, Mount Manager, which assigns drive letters to volumes, does not recognize the mapped network drive and assigns the next available drive letter to the new device or volume. This causes a collision with the existing mapped network drive. To prevent this issue from occurring, when you map a network drive, assign the highest available drive letter to the mapped network drive. To work around this issue if the new volume appears in Disk Management, specify a different drive letter for the new device or volume. To do this, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Disk Management. 3. In the list of drives in the right pane, right-click the new drive and then click Change Drive Letter and Path(s). 4. Click Change, and in the drop-down box, select a drive letter for the new drive that is not assigned to a mapped network drive. 5. Click OK, and then click OK again.
May 29, 2007 | BYTECC Aluminum USB 2.0 5.25'' External...
Archos Jukebox Studio 20 MP3 Player Logo
298 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
