Sometimes when i take a picture the screen goes black and it doesnt record the picture. I also noticed that the batteries were warm. I don know if this is normal. Then all of a sudden it starts works okay?
Similar problem... It seems to be going through batteries, rechargable originals, other rechargable, or new alkalines, very fast and with very limited shelf life for batteries in camera. I may or may not get a low batter warning when taking a picture and the camera will shut off. Also, no picture is taken. The lense will stay out, but I can turn the camera back on and the lense will move. Further attempts to take a picture also fail with the same results.-   Masnor
Dec 06, 2007
-   Loaded with fresh batteries the camera turns on and is able to focus. As soon as a photograph is taken the lcd screen turns black and on restarting the camera the image has not been stored. This problem started intermittently and is now all the time. Any solution would be gratefully received Thanks john-   johnsmiffy
Nov 27, 2007
-   The camera screen goes blank after a few pictures and the shutter is locked out. The picture taken just prior to the screen going blank is not stored on the chip. If I hit the power button the camera seems to function back to a normal screen but as soon as I press the shutter button the screen goes blank and the camera freezes up.
This sounds like there is an internal short which is draining the batteries as soon as you put them in. Were the cameras taken in from the cold to a warm room? that will cause internal condensation which can fry the interior. Clean out the battery compartment completely, be sure no metal is floating around in there, and be sure that you have the polarity of the batteries correct. If that doesn't help, send the camera back to Fuji if in warranty.
I can turn on the menu (green check) but when I turn the selector to camera and push the power...
(More)
I can turn on the menu (green check) but when I turn the selector to camera and push the power button the lense opens up and goes out but I see no screen in the back
camera will not come on - changed batteries - camera will not charge in 2 different cradles. fuji...
(More)
camera will not come on - changed batteries - camera will not charge in 2 different cradles. fuji E550
fuji E550 camera The green colour sensor has gone wrong and I get pink pictures (or, sometimes,...
(More)
fuji E550 camera The green colour sensor has gone wrong and I get pink pictures (or, sometimes, totally dark ones). Strangely, it improves if the flash is on.
