Question about Microwave Ovens
Turntable no longer turns
Our turntable is no longer turning. If we remove the glass tray the spindle will turn. But with the anything on it, it no longer turns. I have the same problem on a Emerson Microwave ( model MW 8105SS )I need a new motor and looking for a parts diagram for part number and a place to buy it. The problem is the plastic shaft that goes into the round magnet in the motor housing is worn and slips.Any help will be greatly appreciated, Thanks Robert
  • Microwave Ovens Master
  • 9,098 Answers
That would be the turntable coupler.
For more help from Emerson : http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
Posted on Nov 26, 2007
Oster microwave turntable will not turn, food on one side is hard as a rock
hi suzanne.
If the glass tray in your microwave doesn't turn, it may be due to a broken drive motor. Most units have a round glass turntable which has a motor driven coupler and roller guide turning the tray. To access the motor, first unplug the microwave and remove the bottom panel.
How to Repair a Microwave Tray That Will Not Turn - PartSelect
microwave turntable will not turn Google Search
Nov 07, 2017 | Oster Microwave Ovens
Turn table in microwave wont turn
Repairs are expensive. New microwaves are cheap. But you don't have to spend a dime on either. If your microwave turntable stopped spinning, here's an easy way to try and fix it. And all you need is some warm, soapy water and your own two hands. You don't have to be an appliance expert to troubleshoot a seemingly broken microwave turntable. You might find that all your little Zappy needs is a checkup and a good, thorough cleaning. If you follow these steps and find that your microwave still isn't turning, it probably means the motor has spun it's last spin. Then it's time to retire old Zappy. Unplug the microwave. Safety first, kids. Remove the glass tray and the circular turntable guide. Wash them both in warm, soapy water to get rid of anything stuck. Pay special attention to the rollers on your turntable guide, making sure they're able to spin freely. Clean the internal cavity. Make sure to check your microwave's center cavity to make sure it's free of movement-hindering (and gross) leftover food. Check that the drive bushing is working. Make sure that the drive bushing, the plastic mechanism in the bottom of the microwave's interior that the glass tray turns on, isn't worn out or split in two. If it is, you'll need to have it replaced. Put it back together. Put the turntable guide back into the circular groove. Place the glass tray turntable over the turntable guide and onto the drive bushing. Adjust until the drive bushing should fits perfectly into the grooves of the glass tray. Test it out. Zap a mug of water for a short bit to see if you fixed the problem. Do not run the microwave without anything in it.
Aug 05, 2012 | Microwave Ovens
Turn table turns some of the time
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Walesarumi
Sep 26, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
The glass tray no longer turns.
The turntable motor that turns the glass tray has become defective, the only way to fix this, is the motor must be replaced.
Mar 24, 2011 | Microwave Ovens
I have a built in convection/microwave oven model AWM540IX, the turntable is not turning, is there anything I can do or will I need to get professional assistance?
Good luck....
Mar 21, 2011 | Whirlpool Microwave Ovens
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have the CWM 100 - the microwave is only about 1-1/2 years old. It runs, but the glass turntable no longer turns. No matter what we've tried, removing the glass plate, cleaning the wheels of the...
Check to make sure the Spindle that the plastic piece fits on is turning when the oven is on.
If the spindle turns, your problem is either the plastic wheel adapter is worn or not making proper contact with the spindle. You can replace th e adapter by going to Cuisinart.com.
If the Spindle is not turning, you can go to Cuisinart.com and find the nearest repair facility.
Nov 20, 2010 | Cuisinart CMW-100 Microwave Oven
RVM1435 Turntable not working
The turntable motor can be replaced by following these simple steps:
1. UNPLUG the microwave before servicing.
2. Locate and remove the screws around the perimeter of the bottom panel of the microwave (located UNDER the microwave bottom).
3. With the screws removed the panel will open, exposing the turntable motor. Remove the glass tray and reach inside the oven cavity and grasp the turntable spindle. Pull straight up to remove it from the motor shaft.
4. With the spindle removed, disconnect the motor connector plug and mounting screws.
5. Insert new motor and reinstall everything using the steps provided in reverse order.
If you have any questions, please let me know. I hope this helps you.
NOTE: If this microwave is mounted, this repair can be performed without uninstalling the oven.
Aug 15, 2009 | Hotpoint RVM1435 Microwave Oven
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Your problem is either a weak or slipping motor or a broken / cracked turntable coupler. If the coupler turns loosely without actually engaging the motor, it is bad. If the coupler is good or looks good, it's probably the motor. One test of the motor is to firmly grab the shaft with pliers and try to gently turn it. It should turn with some resistance and make a whining sound as it turns, since it is a highly geared motor. If the motor turns very very freely - or not at all - then it is bad. You can see an exploded diagram and order parts via the Jenn-Air (Maytag) Web site at http://services.maytag.com/abs/PartsStore.do?nextPage=psstartpage You will need to enter your full model, which is apparently one of the following: JMC7000ADB JMC7000ADQ JMC7000ADW Referring to the CABINET-BASE-CAVITY diagram found there, you will see: - REF 23 motor - REF 27 coupler One of those is likely the culprit.
Dec 06, 2006 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
201 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
