Try pressing and holding the Clear/Off button for 3+ seconds. The LOC indicates the control panel lock is enabled. The LOC should clear from the display. Note: if you hold the key pad for too long, the lock will reengage. From the picture of your range that you included, I believe this is the key pad button just below 7 to the right of the LCD display. There is a label in a small font just below the key pad. (The label probably is a padlock symbol and the word Controls but I can't resolve it from your picture.) Some newer Frigidaire Gallery ranges have a key pad button with a padlock symbol; this would be the correct button to press and hold on those models.
Warning: on some models, the door lock will also engage. Do not try to force the door open. Wait for 15+ seconds for the door lock mechanism to fully disengage before attempting to open the door.
LOC means that the control lock has been engaged. (This feature also keeps a child from changing any setting when a load is in progress or starting the dryer with the cat in the unit.) On at least one Frigidaire dryer, press and hold the Options and Select touch pads for at least 10 seconds (until the display changes) to toggle the lock on and off.
Usually, the two keys to press for the Control Lock will have a line between them with a padlock symbol in the middle of the line. (This symbol will be in a very small font.) This may help you find the keys to press if other models of Frigidaire dryers use a different combination of touch pads.
Unfortunately, a US keyboard is set up to send out keycodes for the US symbols. If you're using Windows 7, this information from Microsoft may be helpful.For XP, you can try changing your regional settings in the Control Panel (Start > Control Panel > Regional and Language Options). You can try changing the keyboard layout and see what happens.
One sure way to get the symbols from any keyboard is by using alt codes. Hold down the ALT key and (on the numeric pad) press 0128 for the Euro symbol (€). ALT-0163 gives you the Pound Sterling symbol (£).
The Key Symbol means the controls have been locked. Either by accident or intentionally. If you don't have the code to unlock the controls. Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 30 minutes and plug the unit back in, turn the Master ON/OFF Switch to ON. The heater should have reverted back to the original factory settings. Now, you can change the settings to whatever you prefer. Just stay away from the Lock-Out button.
Hop this helped you solve the problem. Please let me know. Thanks.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
In the Mouse Properties window:
Click the Device Select tab to disable the touch pad and track stick.
Click the Touch Pad tab to adjust touch pad and track stick settings.
Click OK to save the settings and close the window.
Hi there please follow these key. Press FN+ F7. these key use for mouse pad enable / disable purpose. F7 key should marked a mouse pad symbol. Otherwise please watch those symbol in below the image & press that key with FN.
Thanks & waiting for your feedback.
You can't make the alternate characters like °, ®, ♂, σ etc with a combination number pad. You need to have a seperate number pad. I use a $20 plug in keyboard.
