Where can I get one?
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
SOURCE: Can my kenmore chest freezer be in the garage during hot summers and cold winters in Minnesota?
Jeremy,
You can put a fridge/freezer in the garage. Be sure that the area is level so you don't warp the case which will cause sealing problems with the gasket. Also, clean the condenser frequently as dust and dirt will reduce efficiency.
SOURCE: 15 cu. ft. chest freezer
Remove the back panel, if there is one, find the compressor. Put your hand on it. If its very hot, you have a problem. You should feel a slight vibration if good and running. If The overload is shutting off keep your hand there and wait a few minutes, see if there is a clicking noise coming from the compressor. This is just a start, but you said it has been off for a while so my first suspect is a compressor. Do these things and let me know for a follow up.
SOURCE: Excess frost not keeping food frozen
you have a refrigeration issue. let me guess. is the frost real thick around a small area not the entire lining? if so you have a restriction or leak. cheaper to replace by the way
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
