Question about Sanyo DS25390 TV
Cable connection broke
My cable connection broke so I was going to take the box loose from the board so I could purchase another one. I broke that part of the board loose. Is the tv junk now? or can I fix it.
    Sergeant:
    Champion:
  • 346 Answers
It can be repaired.otherwise replace tuner
Posted on Dec 22, 2007
How I do I repair cable connection from back of TV. It broke off when I tried to unscrew the cable to it
unless you have excellent desolder and soldering skills plus the special tools needed, you will have to replace the board that the broken connector is on. Or use a cable box/satellite box and the component, composite, or HDMI input
Oct 20, 2014 | Seiki Televison & Video
Our 42" Vizio will not display/play sounds when
Hello
One board takes in the HDMI as well as the other signals. Sometimes part of the board breaks and that is what sounds like has happend in your case. This is a fairly common problem and most people tend to just live with it. Others sell thier tv and a few find the number of thier board to see if one is available on ebay or shopjimmy. If you are comfortable with electronics the board is not hard to replace.
Im sorry your HDMI broke....
I hope this helps
Nov 28, 2010 | Vizio VL420M 42 in. HDTV
THE ANTENNA IN HAS BROKEN OFF I UNSCREWED THE BACK OF THE TV AND IT IS A SILVER BOX ...IS IT TO BE REPLACED OR IS THERE ANOTHER WAY TO REPAIR THE ANTENNA IN SCREW PART
The temporary fix for this issue never lasts and it will soon break again. I have seen some shops charge over 100 dollars to get the TV working again, but later the part breaks off again. The threaded part that is broke is from the tuner that is on the main board.
The only real way to fix the problem you have is to purchase a new main board.
Next time use a "slip" connecter (not a threaded one) on the back of the TV for the cable connection.
Oct 06, 2010 | Televison & Video
Where can i find a cable for my HDTV (the kind that get screwed in)cables? its a Mitsubishi WT-46805
Hello sounds like the coaxial connector has come off or broken off the tuner, You can repair this problem using the old connector that broke off by taking out the tuner and resoldering the center pin back to the tuner board (provided the small tuner board is not cracked) and the out side of the connector to the tuner housing for ground. If you are just using or referring to a common coaxial cable to purchase, you can get these from everywhere Radio shack, Fry's etc. Also ur local cable company. If all else fails use the rca output jacks from the cable box if u have one and connect it to video input one on the back of the television, make sure you change you television input to video one if u decide to do it this way.
Oct 24, 2009 | Mitsubishi WT-46805 46" Rear Projection...
The cable for the front drive broke, where can I get a new cable. the cable broke loose at the top where it connects.
Note your Model Number and click HERE for parts drawings. Locate your part number and call your local shop for purchase.
Hope this is helpful,
Dolf-
Oct 18, 2009 | Toro Lawn Mower With Toro Power Tools
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Cable connecter broke off?
It would probably cost more to have someone fix it than just replace it.If you or someone you know can use a solder iron you might get lucky and resolder conections, but most times its too hard to get at the circuit board to affect repairs and the connector usually gets mangled so bad it won't fit right anymore. Or you can try to avoid using this connection and use a different input. But you would need either a cable/satellite box or vcr (with the same kind of connection that broke on TV) and change the input used on the tv to the new connection such as 3 wire AV connection (with the yellow,red and white wires)
Apr 26, 2009 | Sharp 25H-M60 TV
Parking break is loose or broken. Need to know how to tighten or repair. It seems as the weld has broken as well. It engages, but I have to pull the parking break very far
If your parking brake is loose than you have to take off your center console box. Leave the parking brake off and when you take off the box you will see the cable from the handle connecting to two cables that go to the back. You can adjust from there. If that doesn't solve it than it might be broke and you'll have to check everything
Apr 22, 2009 | 1997 Mitsubishi 3000GT
BROKE THE CABLE
Radio Shack MIGHT have the part. That little box was the connector assembly and is soldered on to the circuit board. You will need to unsolder the broken connector and solder in the new one. Either that or duct tape and be careful?!
Jun 18, 2008 | Televison & Video
Televison & Video Logo
138 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
