All flashing usually indicates loss of memory. Was the battery replaced within 5 years? Also, this will happen if battery is not charged by plugging in at least once per month
None of these are the right answer, I had to work it out for myself.
There is an arrow flashing between the two zeros. This is indicating that another till I'd is being used (presumably you switched by accident). To stop this in order to take a z-reading, press "2", then press the "ec/id" key. Take a note of the amount t registered under this id, then press "cancel" to reset to zero. You can try this same method with any number that you may mistakenly be signed into, it's not necessarily always gonna be id "2".
SOURCE: need instruction manual sharp xe-a101 electronic cash register
You can get the manual here.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000003777.pdf
Good luck
SOURCE: cash register PE ondisplay and nothing will work
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall.
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
royal 110cx User
royal 115cx User
royal 130cx User
royal 425cx User
royal 435dx User
royal Alpha-580 User Programming
royal Alpha-583cx User Programming
royal Alpha-600 User Programming
royal Alpha-600sc User Programming
royal Alpha-601 User Programming
royal Alpha-710ml User Programming
royal Alpha-9155sc User Programming
royal Alpha-9180sc User Programming
royal TS4240 User Programming
SOURCE: ipl for sharp cash register XE-A203 / XE-A213
MY NEW ELECTRONIC CASH REGISTER SHARP XE-A203 DSPLAYED IPL ON IT . WHAT DO I DO??
SOURCE: SAMSUNG ER-5115 SAM4S CASH REGISTER LOCK-UP
Turn off the machine. Hold down the lower right key on keyboard. Turn key to P. Turn on machine. That should clear it out. It will also log you off you will need to log back in. Make sure you correct your mistake
SOURCE: my sharp xe-a106 cash register is displaying an
Press the "clear" button (CL) the press the subtotal button (#/SUB). It will print out a long receipt. Make sure to run a Z after to clear all sales before.
