Question about Hotpoint Aquarius WF000 Front Load Washer
Replacing door seal
Existing door seal black and mouldy
    Problem Solver:
  • 8 Answers
Try washing the seal with jiff and a scouring pad in warm water.Depends on how well it is ground in.
You may have to replace with new seal.
slimjim1
Posted on Nov 26, 2007
Lg tromm washing machine
Best way is to use washer cleaner or some mild bleach sulotion and leave door open after each use
Dec 10, 2013 | Washing Machines
I have a front loader washing machine. The rubber inside is going mouldy. I have tried to clean same without success - any suggestions!
Unfortunately, once the door seal goes mouldy it is impossible to get clean. Only option is to replace seal. Once seal is replaced, you need to wipe it dry after each wash and leave door ajar to prevent reoccurence of mould.
Mar 09, 2010 | Maytag Washing Machines
The rubber section of my Hotpoint WF640P has gone mouldy
The problem is basically caused by doing too many low temp washes.
The scum you refer to is actually bacteria that is bulding up on the door seal.
To avoid this problem reoccuring, the best thing to do is to have the door seal replaced, and periodically do a high temp wash with powder in, but without clothes..
This is called a maintenance wash, and is recommended by most manufactures
Also, after each wash, clean and dry the door seal, this will help prolong it's life.
Hope this helps answer your question.
Please rate my solution.
thanks.
Dec 23, 2009 | Washing Machines
Door seal is mouldy? Clothes are smelling. can we get a new seal?
Yes You can buy a new seal at this web site repairclinic.com or you can call them at 1800 269 2609.
Good Luck and please Rate
Sep 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Can you replace the door seal on the miele w404 washer as it is mouldy and we have been unable to clean it?
YES IT IS EASY TO REPLACE:
YOU HAVE 2 RING OF TIGHT:
1-BETWEEN THE OUTER CASE AND the door seal
2- BETWEEN THE SUD CONTAINER
AND the door seal
USING SMALL PLAYER AND SUITABLE WRENSH ,SCREWDRIVER
THANKS
Jul 28, 2009 | Miele W404 Washer
Mouldy Door Seal
Use tilex to remove the mold. Then see what happens. If the mold comes back right away it may be a problem with the rubber gasket not seating as it should. Let me know. And please rate my solution. thanks.
Feb 02, 2009 | Zanussi ZWF1430W Front Load Washer
How to change a door seal on a hotpoint wma58
Firstly remove band holding front of seal then remove the screws from the door lock and push lock through.
Remove kick plate from bottom of machine &take out 2 screws holding front of machine.
Remove soap drawer &take out screws behind it then bring facia forward & slide to right to remove. Take care at this stage not to disturb wiring on cicuit board. An extra pair of hands would be helpfull to hold it.
Remove screws holding front as you did at bottom then lift and remove front panel.
Seal is now easily accessed.
Post back if any further assistance needed.
Thankyou for using Fixya.
Jan 26, 2009 | Hotpoint WMA58 Front Load Washer
Mouldy rubber seal
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Regarding the mould; keep your door open after yur washing is done, (means dont shut it tight) it will help to dry the insides & prevent moulding. Only see your cat is not inside before starting a new wash.
And pl rate me if helped.................
Jan 24, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Mildew smelling towels and no separate rinse cycle
the problem is your door seal if you close the door after a wash then what happens is the water goes mouldy on the inside of the door seal what you need to do is replace the door seal you will never get rid of the smell without replacing it never close the door after a wash always leave it open to make sure its your seal the easy way is to look at the inner part of the seal and it will be mouldy only thing you can do
Oct 30, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Removing rubber door ring from Zanussi Aquacycle 800
getting it off is not the problem (just find the clip at the bottom of the seal and let it off and you can pull the seal out....getting it or a new one back on is the real problem...that I am looking for help on!
Oct 12, 2007 | Washing Machines
Hotpoint Aquarius WF000 Front Load Washer Logo
190 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
