Question about TV Receivers & DVRs
My Sony tv CRT
My sony tv takes time before lighting the tube.
  • 38 Answers
Re: My Sony tv CRT
If it's between 5-10 secs, that's normal. You will turn the tv on and hear a loud (buzz/hum) that is the picture tube firing up, once it's fired up, it has a few more seconds until your picture comes up fully. That is about 5-10 secs from pushing the power button.
If it's taking longer than that, your picture tube may be going out.
I had a 36XBR250 and it took about 10 secs to fire up and show a picture, and it was 5 1/2 years old.
Posted on Nov 28, 2007
0 characters
3 Points
Sony tv manual
You need to go to directly for the manuals. They are usually in PDF format requiring Adobe Reader.Sony needs to know your make and mod. in order to get support.
Dec 21, 2013 | TV Receivers & DVRs
What is the problem to my Sony TV model KVXS29M65 Chassis BG-3S\51 that had a red tinted screen.Human skin tone looks reddish orange.Pse help.tq
I was not able to find any service information for that particular model. But it could be several things, first it may be that the picture tube has a short on the RED Cathode. If this is the case, toss it, if you could find a new picture tube it would likely cost more for the part than a new TV. Second it may be that the CRT Driver IC for the RED Cathode has shorted. This will be found on the CRT circuit board. There should be three of them, One for each gun, RED, GREEN and BLUE. Unfortunately like I said, I couldn't find the service manual for this model, so I can't give you a location number. They should be fairly inexpensive, so you could replace all three. You can find the part number printed on the face of the IC. Third it may be in the Chroma Circuit, which is also an IC, but again I cannot give you a location number. If your adept at repairing TV's and want to tackle this your self, invest in a service manual, or call one of your local repair shops. Maybe they can / will help with part numbers / location numbers etc.
Jun 13, 2010 | Sony TV Receivers & DVRs
Have an old sony HDTV proj tv, and the picture went out last night. I heard sort of a "pop" then no picture
Pop sound shows that some thing went wrong inside TV and most probably any part got busted.
Let me know model number of your Sony TV and does its standby red light blinking? if yes, how many times it blinks between 3 seconds interval.
Nov 30, 2009 | TV Receivers & DVRs
A tv was knocked onto the floor. How do I tell if
I the picture tube is fractured it will not play for long. The tube has a vacume and loss of this vacume will cause the picture to fail with in an hour.
Nov 07, 2009 | Sony TV Receivers & DVRs
I want to adjust my LG remote control to my Sony tv
I found the DVD LG DVS-8575N manual in spanish on
To set a Sony TV just press at the same time POWER TV and number 8 or 9
Jul 10, 2009 | Sony TV Receivers & DVRs
Sony kv32-fv1 out of focus
You have got a bad picture tube. I'm as sure as i can be without actually seeing the set.
Mar 30, 2009 | TV Receivers & DVRs
Television picture fault
sounds like an issue with the tube but you probably wont be able to fix it on your own, i would take it by an tv repair shop, they will determine if its repairable
Aug 06, 2008 | Sony TV Receivers & DVRs
Sony 46 9x16 tv turns green and goes off
Sorry, this sounds as if you will need a major repair. How old is the TV?
Dec 30, 2007 | Sony 46IN TV Stand Designed for Model...
Arching in Picture tube socket
ok! the arching line is for screen grid, make sure your spark gap is in align! or much better replace a new one CRT socket then clean all CRT board area with laquer thinner...
Sep 26, 2007 | TV Receivers & DVRs
TV Receivers & DVRs Logo
89 people viewed this question
Top TV Receivers & DVRs Experts
Jaime Hernandez
Are you a TV Receiver and DVR Expert? Answer questions, earn points and help others
