Question about Hotpoint Washing Machines
Tapping noise on start of spin - Hotpoint WDD960
Hotpoint WDD960 - tapping noise increasingly loud on starting spin - then spins quietly - with moderate weight washing no tapping noise with light weight washing. No up/down movement in drum. A spring found on floor under the machine a strong spring - short/bent - about W 11mm x L 11 mm. When drum pushed back all the way a knock noise sounds when it strikes something. Any ideas ? would be appreciated - thank you
SOURCE:
  • 13 Answers
SOURCE: Drum noisy when spinning
main wash bearing fail parts for this £48 if you are mechanicaly minded then its a 3hr job if you have all the tools appliance doctor
Posted on Feb 02, 2007
  • 14 Answers
SOURCE: Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Posted on Dec 30, 2007
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
SOURCE: kenmore 700 series washer motor humming noise
ffsdaffdsa
Posted on Mar 30, 2009
  • 68 Answers
SOURCE: loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Posted on Apr 26, 2009
Tapping noise in engine
What's That Ticking Sound Coming From Your Car's Engine?
www.popularmechanics.com/.../whats-that-ticking-sound-coming-from-...
Apr 18, 2014 - My engine has developed a strange ticking sound. Its whisper-quiet before an oil change, and then makes a loud tapping after a new filter and ...
Engine Tapping - Auto Repair Help
www.auto-repair-help.com/auto_diagnostics/engine_tapping.php
ENGINE MAKES TAPPING NOISE WHEN STARTED by Mark Davidson. SYMPTOM SUMMARY The engine emits a tapping noise on start up. The noise may ...
Engine Ticking Clunking Noise - Repair - YouTube
? 9:37
https://www.youtube.com/watch?v=ilDtnJi_BS0
Mar 15, 2013 - Uploaded by knurlgnar24
One of my vehicles started making a rather disturbing sound so I went to investigate and to hopefully fix it.
Dec 02, 2015 | Cars & Trucks
What is the tapping noise coming from the transmission (axod)1989 ford Taurus.
On my Mercedes, it says to only fill it up with premium fuel. If I fill it up with regular unleaded it will knock and ping.
Sep 13, 2014 | Cars & Trucks
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Hotpoint Washing Machines
I have a Hotpont washer/dryer model BWD129 It started making a loud noise for a while when spinning now it won't spin at all. Please could you advise if it would be able to be fixed? Many thanks
I would say your basket drive is broke. Only when spinning, if it was this, it makes loud noises the whole time it spins, big thumps. This may be your problem. You would have to have someone look at it or call for an estimate. It would probably need replaced.
Mar 03, 2011 | Hotpoint Washing Machines
Very noisy when Hotpoint Aquarius WMA46 is on spin
It is the main drum bearings that is causing the noise.
There is no provision made for lubrication.
It can be done as a DIY fix, but it is a very involved repair, as it means having to remove the whole inner workings of the washer,
Not a task I would recommend unless you know what you are doing, and feel competent to tackle it.
Good luck.
Dec 05, 2009 | Hotpoint Washing Machines
Loud tapping noise from 2005 grand prix 3800 engine
It could be you are low on oil;using the wrong oil;a possible loose connecting rod,or,maybe a bad or stuck lifter.
Neil
Mar 15, 2009 | 2005 Pontiac Grand Prix
I have a 91 legacy GT and theres quite a bit going wrong...when you start her for the next 20minutes or so theres a taping noise which increases as you accelerate...going around corners a loud noise comes...
hi you have a worn camshaft it always makes noise when worn the tapping sounds louder when you accelerate.its important to have regular oil changes as the oil ways can become blocked and lead to this type of trouble if oil changes are over looked.also check for worn big end bearings that connect the pistons to the crank shaft.
Nov 01, 2008 | Subaru Legacy Cars & Trucks
Whirlpool Washer won't drain or spin
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
Mar 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
