Question about Hotpoint Washing Machines
Tapping noise on start of spin - Hotpoint WDD960.
5 Suggested Answers
SOURCE:
  • 51 Answers
SOURCE: how do i get to the pump on the hotpoint wdd960
REMOVE PLUG from the wall socket. at the rear of the machine you will see a small panel at the bottom, remove the 3 screws holding it in place and have someone hold the front of the machine tilted forewards. you will see the sumphose that collects foreign objects that have entered the machine, if this is full it will not empty effiecently or not at all. the pump its self is next to this sump.
Posted on Feb 02, 2010
beltronic205
  • 1479 Answers
SOURCE: Hotpoint WDD960 Washer Dryer - no error code but
Sounds like heating element is not coming on ..Heating first then with a Fan motor running and water flow the steam that is produced by the heaters are changed to water by the cold water over a condenser , the pump then puts his out to waste..
Posted on Jan 28, 2011
  • 6277 Answers
SOURCE: how to change language to
Methinks you could do with a manual- and for the future!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Apr 16, 2011
Testimonial: "Thank for your reply but i have the manual and waiting for manufacturers reply. Again thanks "
  • 118 Answers
SOURCE: hotpoint ultima WDD960, My washer dryer has
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • The best thing is to see if it is filling and draining properly
Posted on Dec 31, 2011
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Hotpoint Washing Machines
Hotpoint ultima WDD960, My washer dryer has stopped mid wash cycle annd is displayinh F:o5
Oct 28, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WDD960 Washer Dryer - no error code but whenever I put it on a dry cycle it just spins as if working but without actually drying. Any suggestions?
Jan 28, 2011 | Hotpoint Washing Machines
How do i change the language on my washing
Press and hold the drying,delay start/temp select buttons altogether for 5 sec untill you hear a beep, then release all 3. press the dely start button to scroll through the available languages then select your chosen language by pressing the drying button once.
Apr 07, 2010 | Hotpoint Ultima WD72 Front Load...
Hotpoint wdd960 washer dryer error f05
f05 means blockage and cannot drain-switch off at mains to reset error-turn to drain if pump runs but dont drain filter in sump blocked/if no pump action then somthing is jammed inn pump
Nov 08, 2009 | Washing Machines
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
