Question about Crosman (4032)
Repairing i am trying to reassemble the trigger mechanism for the rifle and have it all together except for the spring on the trigger? cant seem to figure how to put it back in     help?
  • 1 more comment
  • Anonymous Mar 02, 2008
    I have crossman 766 rifle and need a picture to put it back together
  • chrisNofix Mar 30, 2008
    i have the same problem as danielconn, could use a schematic or manual picture to help orient where and how the springs fit.
  • mrrobin11 Dec 17, 2008
There are two manuals for the 766 on this page.
My problem is figuring out how to take it apart.
Posted on Jul 26, 2009
How to fix air pump
The crossman phantom is a spring powered air rifle which means that you pull the barrel down through the arc of its travel until the piston locks up to the trigger mechanism in one continuous movement
Feb 08, 2016 | Crosman Optics
I have a Poulan 5020AV. The thing cuts wood like a woodchuck on crack! The problem I'm having is regarding the reassembly of the handle/trigger mechanism. I took it apart in order to remove/clean the carb....
Anytime I get into an unfamiliar saw I always take a number of pictures with the I-phone to help with reassembly. Not too much help is it?
It will only go together correctly ONE way. Do not force any of the parts as if you bend the carb linkage, you will forever have a problem with it. A hint: sometimes the parts have to be inverted and slowly twisted or turned back upright to install.
Jan 17, 2015 | Poulan Garden
Assembly instructions for reassembly. I had to disassemble glue to clean and the spring popped out and I am not sure how it goes back together
the spring goes behind the trigger, but i would need to know the brand and model glue gun to really help with this problem
Nov 17, 2010 | Crafts & Hobbies
I have a beeman rs1 chinease air rifle is the trigger adjustable and if so How?
Yes they are adjustable, both 1st and 2nd stage and also trigger weight.
The trigger group is easily disassebled and honed with fine emery paper. You really dont need a mirror surface but the factory surface is very far from smooth. There are som sharp corners on the sear and the trigger lever, DO NOT ROUND THEM.
Pay close attention to the three small springs inside, if you get them mixed up the rifle will not lock.
This work will make all the difference in your rifle.
Just work slowly and with caution not to change the angles in the trigger geometry, all you want to do is polish the surface.
Tutorial can be found here
Mar 21, 2010 | Beeman Optics
Need a repair manual four a crossman 177 cal pump need to put it back together
found a picture how the trigger and springs set up worked all i needed was where one spring went.didnot find a manual on the web. thanks
Mar 10, 2010 | Crosman Phantom .177 Caliber Break Barrel...
Trouble reassembling a daisy buckmaster 840 bb gun. We can not figure out the trigger mechanism in order to fit the side panels back into place.
1) Stack the trigger, seer (long black metal piece) and trigger block (large L shaped silver piece) on top of each other, with the seer in the middle.
2) You should have 3 springs, the long one attached to the end of the seer, the skinny one on the bottom of the seer and the fat one back between the trigger and trigger block on the back side
3) Compress the trigger block and the trigger together thus compressing that spring between them, keeping everything together. Now back the entire unit into the stock cavity. This is tricky and will take some practice. Be sure to keep the pieces squeezed together.
4) Insert the pin through the side which is countersunk. It only goes one way.
Jul 19, 2009 | Toys
Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
Jun 01, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Crosman (4032) Logo
1,197 people viewed this question
Top Crosman Optics Experts
Martin Clarke
Martin Clarke
Are you a Crosman Optic Expert? Answer questions, earn points and help others
