Question about Samsung SCH-u740 Cellular Phone
Cell phone dysfunction
The inside screen just went white. After powering off and restarting, the outside screen registers normal but the indside one is still white. Battery was recently charged and after checking inside, there is no sign of tripping the moisture indicators, nor was there any abnormality previously. i had just talked with someone and it went white!
  • momsta45 Nov 29, 2007
    thanks for the response! phone owner is at school, I'm hoping he can get a diagnosis from cell provider and possible replacement.
I am not sure on your phone but the screen on my wife's u740 turned white right after I dropped it. I had to get a new phone because I didn't look into replacing the lcd first. That was the discription of my problem from verizon was a pressure crack in the LCD. I hope that helps.
Posted on Nov 29, 2007
How so i get rid of the "white screen of death"
Hold down power button for about 30 seconds (or until phone recognizes power off), let it shut down.Afterwards, hold power button down maybe 10 seconds, release and let it reboot. If it performs normally, great. If not, check the following page:
Fixed HTC Stuck At White Screen of *****
Sep 13, 2017 | HTC Sensation 4G
Blan White screen
try holding the power and the square at the same time till it shuts downand the apple logo shows up then release
May 12, 2010 | Apple iPhone Smartphone
Screen went solid white cant get it to do anything inside, outside works ok
If you haven't tried to power it off and on then do that. If you haven't removed the battery and checked for water damage that is what you do next. If there is no water damage, replace battery and try to power the phone up. If you still have a white screen, you may have a manufacture defect. Take it to the store or call tech support on another phone otherwise they won't be able to troubleshoot with you if you are using the phone with the problem.
Mar 28, 2010 | Casio G'zOne Boulder Cell Phone
White screen when turned on inside and outside
The cable that connects the screen to the phone is damaged, causing it to white screen. Other than sending it back to the manufacturer or having Nextel fix it, there's no fix other than for it to be swapped out.
Nov 18, 2009 | Motorola Mobility i776 Cell Phone
My screen went white...
you need to change the flex cable inside that connects the LCD to the mainboard.
Jan 02, 2008 | Samsung SGH-t629 Cellular Phone
Blank screen
papdaddyz - replace both the LCD and teh flex cable.
bjantnymom - replaced the LCD screen.
Nov 18, 2007 | Motorola Mobility RAZR V3
White screen`
the white and black screen issue on the Razr V3xx can be a bad LCD. If the LCD is good then the issue is on the main board. The most common failure is broken contacts on FL6505 and FL6504. resoldering might hold up for a while but replacement is the best option.
the side view clearly shows the damage to the filter. this is only visible after the solder is removed.
hope this helps.
Oct 07, 2007 | Motorola Mobility RAZR V3
V3's External screen acting up, keyboard and displays turning off, phone doesn't let me perform any functions
this could be a firmware problem, though i have not known motorolas to have firmware problems.
Sep 08, 2007 | Motorola Mobility RAZR V3
Blank screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Aug 27, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola RAZR V3 Cellular Phone
Ok so when I close my phone I still see the time and my background picture but no light immanates (hope I spelled that right)from the screen if thats what your saying that's normal. Now as far as the inside screen if you dropped it the connection that lets the phone know it's closed may be jarred lose and offset (not sayin u dropped it)although you say it dims. When you close your phone the inside screen should turn white and then turn off just barely have your phone open to check, if it does this then the connection is working. And you need another opinion.
Dec 07, 2006 | Motorola Mobility RAZR V3
Samsung SCH-u740 Cellular Phone Logo
366 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
