SOURCE: weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
I just bought one of these, and I'm having a similar issue. The positive terminal of the AAA battery and its associated contact point become corroded quickly. The short term solution is to use a small screwdriver to scratch some of the corrosion products off of the contact point, and put in a new AAA battery (or clean the old one). I'm going to try to clean the contacts and apply a little petroleum jelly at that spot. Hopefully, this will prevent the corrosion...
SOURCE: In June I bought a new Weber grill but the auto
If there is no click, it is most likely the igniter module is bad. The igniter module should be available at any Home Depot or Lowe's; in any case, your owner's manual will show you how to remove and replace the igniter module. If you don't have the owner's manual, I will include a link to one online; you will need Adobe to open it. Here is the link: http://www.bbq.us.com/images_templ/weber-manual-3741001.pdf
Try this and if it doesn't fix your problem, come back and let me know and we will troubleshoot further. Good luck!
SOURCE: How do i change the battery in my weber genesis
just a stab in the dark but my grill has the battery in the ignitor button itself just unscrew the lid and replace it i hope this helps
