I've seen people buy adapters to power their cordless drills with an outlet, but they had problems because the outlet didn't have enough raw power for the drills. That leads me to believe an 18v drill pulls some serious amps at full torque and rpm, but the exact numbers would depend on the battery discharge capability which varies on big and small batteries as well as they load if it isn't maxing out the drill.
SOURCE: chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
SOURCE: lost 18V AC adaptor- can I use one made for laptop with 18V output?
I don't know if I would try this or not. there could be a difference in the amps and usually a charger is designed to shut off or go to trickle when the battery is fully charged.
SOURCE: 18v makita bhp451 cordless hammer drill.clutch
its prob stuck between gears one and two try a little wd40 on the gear selector switch
SOURCE: Need to replace power cord to battery charger of cordless drill
it takes a 24V DC 200mA The one I have is a Ktec Model KA12D240020034U
