Question about Video Cameras
Sound Problem Camera Has No Sound In Play Back Mode. The Volume Control Has No Effect. After recoding on the Samsung SCL0700 8mm camcorder, I am unable to hear anything in the playback mode.
5 Suggested Answers
  • 473 Answers
SOURCE: Sound Problem
Be sure you are not playing back in "camera mode". If this is the case, change the power switch to "play mode" and resume playback. This should solve the problem. Some models have a Speaker On/Off function in the menu as well. Consult the User Manual for more information.
Posted on Sep 06, 2005
  • 10594 Answers
SOURCE: no sound on playback
I think, built-in small speaker is not working. try to replace it.
Posted on Jun 11, 2008
  • 2794 Answers
SOURCE: 8mm analogue camcorder tape playback at double speed
If you ran it through that many 8mm players, I'm going to say that the tape has something wrong with it.
You can see visually if there is anything wrong with the tape by releasing the cover by moving the tape and visually inspect the tape for anything that could be frayed. Usually you can see it on the bottom of the tape.
Sometimes the takeup can be messed up in the tape too. Once you release the tape cover, you can turn the white wheels to see if there is any slack in them.
Good luck on that.
  • 5 Answers
SOURCE: Samsung Digital Camcorder VP-D351
hi..Please to pass on the remedy..I had this two weeks ago.. lcd ribbon is brocken.. breaks over time with being opened and closed.. Part available form part no..SAMAD9706489A.. lcd fpc ***. easy to replce ..take you time and try yourself.. if i can help with instructions cost of ribon £11.49.. GOOD LUCK STEF.
Posted on Oct 16, 2008
  • 1223 Answers
SOURCE: During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
Posted on Apr 24, 2009
0 characters
1 Points
When i record and play back video i have no sound
If you are playing the tape in the camcorder, are you sure the volume control didn't get accidentally turned down or off? The control is the thumb wheel on the back of the camera below the viewfinder. See page 22 of your manual. If you are playing the tape in another VCR there is some other problem.
Apr 15, 2011 | Sony Handycam CCD-TRV12 Camcorder
Everio movie editing
First check sound settings on control panel, ensure volume is not at minimum and computer audio is not muted. Test playing a CD.
this is usually due to Media Player or whatever player you use on your pc, not having the right codecs to decompress sound from camera file.
Usually you sort it out upgrading media player, you can download update from links below.
  1. Windows Media Player 10
  2. Cumulative update for Windows Media Player 11 in Windows Vista
Sep 23, 2008 | Video Cameras
No sound on my samsung
if you put a old tape in that has sound in it and it does not playback sound then your internal speaker is bad. easy fix and not to much.
Mar 12, 2009 | Samsung VP-D80 Mini DV Digital Camcorder
No volume on play back.
I hope this doesnt come across condencending as you're used to cameras, but to clarify, the monitor volume on the camera is up yes? Both the volume control and the monitor volume - both in camera?
Jan 22, 2009 | Sony HDR-SR10E HDD Camcorder
Audio in playback mode doesn't work
Hi There, Try this: Connect you camcorder to your tv set via a/v input cable. Put camera in cam mode so you can see the picture on the tv. Turn up the volume on tv and if it squeels, the mic on the cam is ok. Record something and then play it back on the tv, if its ok, then all your audio is functioning. This means that the SPEAKER on your camera is defective.
Thanks, mr cicmo
Dec 26, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
i have this same problem for a while and just stumbled on the (yet to be verified) solution. if this settlement is legitimate then Samsung will repair for free! (and refunds for people who paid Samsung to repair). the site asks for contact info but i worry about scams so i'm going to contact Samsung directly.
i hope this is real!
The affected models include:
SCD 23, SCD 27, SCD 103, SCD 107
Nov 07, 2008 | Samsung SC-D107 Mini DV Digital Camcorder
Menu Options
sound or volume can be lowered or turned off using zoom control button
Aug 30, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Can my camcorder work with imovie and if so how do i get my computer to get download my video?
Open iMovie and set it to capture DV. (Click the camera shaped icon opposed to the siscor scissor shape) When you see a blue screen that says (camera connected) and the image pops on screen of image from tape on camcorder set in play mode, you hit the import button and it begins to capture digital movie using DV compression of whatever you have on tape. You should be able to control your camcorder with the video controllers underneath the project window to make selections for the in and outpunts on the tape you wish to capture. Then switch to edit mode by clicking on the scissor button and import the movies you just captured or use them from the clips menu, etc. renedr movie back to tape, if you wish by clicking back and forth from edit mode (scissors) and capture mode (camera silo) and render to and from tape.
Jan 21, 2007 | Canon ZR700 Mini DV Digital Camcorder
Sound Problem
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Video Cameras Logo
116 people viewed this question
Top Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Video Camera Expert? Answer questions, earn points and help others
