Question about Audio Technica AT-PL50 Turntable
Background huming Audio hum present on all MP3s that I converted from albums--sounds as though it needs to be grounded. Example: http://boomp3.com/m/efd0c0139ebd Do I need a pre-amp? If so, any suggestions which (low-cost) one might be best?
  • 515 Answers
How does it sound when you just play straight vinyl through your system? If you still get that hum, issue might also be faulty RCA cables, and even cartridge. So you would need to test everything out.
You don't really need a pre-amp unless you are connecting straight into your pc from your turntable. In that case, yes you will need a pre-amp, and this actually might be the cause of everything. If you are going into a DJ Mixer or a receiver, and your turntable is connected to the PHONO INPUT connection, you do not need a phono pre-amp.
Here are some inexpensive PHONO PRE-AMPS.
Hope this helps some.
- TWEAK AV LAB
Posted on Nov 26, 2007
Did not ground my turntable while playing albums. while playing i heard a pop and no more music after that sound
Not grounding it shouldn't have hurt it, might have had some hum but that would be about it
Jan 29, 2018 | Audio Players & Recorders
Loud huming from my 300v low voltage lighting transformer
Transformers make humming sound.
ML300 series transformers make sound.
Used styrafoam to separate transformer from contact with building so sound is not carried.
These transformers have 10 year limited warranty.
Copy following link for general troubleshoot and tips, and warranty information, and trippers.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Oct 23, 2012 | Malibu ML300RTW - Low Voltage Power Pack...
Audio buddy buzz
Background 50 or 60 Hz buzz can be radiated from nearby wiring or conducted. Grounding is important but that can also be a cause. I suggest you search accidental hum loops.
Poor or faulty power supply regulation or smoothing can inject a mains hum into audio. This would need checking with an oscilloscope which could also be used perhaps to help search for the source.
Radiated hum can be picked up and injected into high gain amplifier inputs and long leads, poor screening and impedance mismatch can make things much worse.
I haven't helped much but I hope I have given you food for thought and further research.
May 30, 2017 | M-Audio M Audio Audio Buddy Microphone
BACKGROUND HUM PRESENT AT ALL TIMES
What sources do you have connected to the receiver? The thing to do is to disconnect your sources one at a time and see if one of those eliminates that hum.
Jan 03, 2011 | Audio Players & Recorders
How can i connect a gemini turn table with a ground cable to a input that dont have the ground connection gchristinam@yahoo.com
See if you can attach the ground wire to a point on the chassis of the device you are connecting it to.
Sep 06, 2010 | Gemini XL-500 Turntable
I have a Sony STR-DG520 5.1 receiver. My problem is that I can hear a high pitched background whine from all the speakers, even if the volume is set to zero or muted! If I switch the audio source off, the...
do u have the unit earth grounded? sounds like AC hum, most amps have a ground lug, make sure that is grouned and the power plug to o the amp has a good ground.
Jun 15, 2010 | Sony STR-DG520 Receiver
When amp is turned on it hums.
If the hum comes out of the speakers then it could well be the large Electrolytic Capacitors in the power supply stage. Otherwise any part huming inside the amp should be replaced, though sometimes a part may hum due to a faulty part elswhere.
Feb 17, 2010 | Peavey Audio Players & Recorders
Humming sound to speakers from amplifier
It sounds like you may have a ground loop issue. I'd start by checking all the power and ground connections. Then disconnect the RCA wires from the amplifier. If the hum goes away then you should try grounding the stereo to a better grounding point, the factory grounds are usually not very good at all. Then try it again, if it is still there try replacing the RCA"s.
If the hum is still there after you've redone the connections and replaced the RCA's, you may need to install a ground loop isolator.
Both www.crutchfield.com and www.sonicelectronix.com sell good ones.
Hope this helps
Mar 28, 2009 | MTX X Thunder 1000XD Car Amp
Humming sound in receiver...being transmitted to ceiling spaekers
Low humming sound is invariably the ripple of the AC mains supply breaking through.
Sometimes it is radiated from nearby wiring, sometimes it is caused by a hum loop and sometimes it is an indication the capacitors in the power supply are failing.
Feb 27, 2018 | Denon AVR-484 5.1 Channels Receiver
Audio Technica AT-PL50 Turntable Logo
157 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Michial Gueffroy
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
