Question about Quorum Ceiling Fan - 138880
42" ceiling fan
Motor hums but fan does not spin when the wall switch is turned on
  • permster Apr 05, 2008
    My fan is doing the same thing. It just hums when I turn on the fan. I tried spin it and there doesn't appear to be anything mechanically wrong. Then I tried to spin it and quickly turn it on, but it doesn't turn the blades.
    Any ideas on a next move? Is the motor bad at this point?
    Problem Solver:
  • 16 Answers
1. Try to rotate it by free hand and see it is free machanically. If not, it ball-bearing/bush should require lubrication or replacement.(Note at this satage there should be no electric supply to fan.)
2.If it is free, rotate it fast by hand, then immediately switch it on.
a)If it continue to rotate, then there is fault in capacitor.Replace it.
b)If not, ask me.
Posted on Nov 29, 2007
Trying to find manual for a Hampton Bay ceiling fan. I have two. Tag on fan says model: AC-552AL, Item# 154620 NN, Another sticker on fan says 05/02 E192641 UL Listed CEILING FAN 47BF
You should find what you need here:
Apr 03, 2017 | Hampton Bay Dryers
Ceiling fan hums as soon as power is applied. construction grade fans .
Is there a switch on the wall supplying power to the fan? If it is a light dimmer switch the fan will hum loudly. Make sure the switch is a ceiling fan speed control switch. If you have a fan and light combo and only one switch / hot lead you will need to install a simple on/off toggle switch.
Mar 14, 2014 | Computers & Internet
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    I have 2 Hunter ceiling fans and the wall switch has 2 knobs which you push to click on or off.......after you click can turn the knob and increase or decrease the fan speed. You can click on both...
    Hello .. you should be able to find a replacement for your fan control at any building supply store, a home depot type store. Look or ask for a variable speed fan control. This is slightly different from a normal liight dimmer . You might also look for a replacement knob before replacing the whole switch, or matbe getting a replacement just to replace the knob ..
    Jun 18, 2010 | Hunter Ceiling Fan Control Switch
    Blades will not turn
    The motor probally damaged while you are moving the fan to the new house.
    Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
    I just purchased and installed a Hampton Bay palm beach 48' ceiling fan (close to ceiling mount)Problem is when turned on I hear an annoying hummmmmmmmmmmm, more of a hum at high speed and it graduates...
    You have a rotating dimmer switch on the wall to control speed right? If so, it is the wrong type switch. The missed matched switch will cause the humming. Use a regular on/off switch and control speed with the pull string
    Apr 29, 2009 | Madison Avenue 04317 Hampton Bay Ceiling...
    Quit working
    first turn it off, then rotate the fan, half turn and try to turn if on again. if it start running again you have a faulty motor, and need to replace it. or if the problem continue, try replacing the switch in the wall.
    Nov 24, 2007 | Hunter 23852 Classic Original Ceiling Fan
    Quorum Ceiling Fan - 138880 Logo
    517 people viewed this question
    Top Quorum Dryers Experts
    Are you a Quorum Dryer Expert? Answer questions, earn points and help others
