Question about Intel Motherboard
Install an IDE HDD in an acer aspire m1610
The bios sees the drive, yet I can't get to data
  • 209 Answers
Probably the hard disk is in generic mode you should format this according to the operating system you'll install, we have FAT32, NTFS etc.the other cause might be the jumper from hard disk might be incompatible meaning, if your hard disk is in cable select and your optical drive is in master this will conflict. check your setting
Posted on Nov 25, 2007
My lenovo got a new harddrive and won't boot at all not even bios what to do? It's a g 560
You have to recover your MBR looks like, but first you need to remove the hard drive and see if it will boot without the HDD installed then get back to me ok. Also sounds like the BIOS may have failed if it wont boot without the HDD installed. But first things first.
Apr 04, 2015 | Lenovo Computers & Internet
Maxtor Basics Desktop 1tb desktop hard drive
is this an external drive or internal?
the answer is based on them.,
if internal drive,
then use BIOS to see if BIOS can see it,
if bios can see, it good, that dont make a drive good
only that it can talk and PNP,
if BIOS can not see it.
1: drive is not plugged in to data and power. (swap cables and ports)
2: or the drives dead. totally, no comms at all.
try all sata power cables
try all sata data ports on MOBO, some are RAID only.
if wInDoZ cant see a drive, no app on earth can either.
always start with bios. that is the first step always.
unless external drive. those are more tricky, ASK !
Sep 30, 2013 | Computers & Internet
When laptop says no bootable device
re-seat hard drive and check settings for boot devices in bios.
run ibm diagnostics and see if it is seeing the hard drive . if it is run the hard drive tests if they pass then you probably have misconfigured the bios settings somehow. if the hard drive is not found or fails the tests then im afraid your going to have to look in to an exspensive data reclamation service, your best bet there is go to the hard drive manufacturer or even ibm itself.
Jun 13, 2013 | Lenovo Computers & Internet
How to solve this Error code 0146 2000-0146 Unit 1: DST log contains previous errors
This is a Dell error code. You have a data read error on the hard drive. It may be a BIOS problem,
If the system still sees a hard drive (check the BIOS, F2 at powerup), purchase a 2.5" USB drive case (EIDE or SATA as appropriate) and mount the drive in it. Attach to a working system by USB and see what you can still read.
If the drive isn't readable or the BIOS won't see it, data recovery is your only option - it is expensive (easily a couple of thousand dollars + ) but probably the only way.
Hope that points you in the right direction and if you can get in run CHKDSK/F straight away, it may help to recover your files!
Feb 25, 2011 | Computers & Internet
Wont recognize ide drive on startup
When you boot,go into the bios. In the main section see if your drive is listed.
If not, turn off machine, open unit, check power and data cables
Harddrive are blue data cables. Also check to see if HD is slave or master. Jumper switches on HD. Clse unit and boot up into bios
in the main you should see you HD
in boot sequence.. see if you c:/ is in the list
bios will tell you how to put in list if not there
close and reboot
Jul 25, 2010 | Dell Dimension 4550 PC Desktop
Ive built my first pc and all went well until the message no hard drive detected comes on all parts are new so any help would be great in fixing this thanks dave
Verify that the hard disk is connected on both data and power cables and is receiving power (it hums at startup); also that the proper EIDE or SATA slot on the motherboard is used, and properly jumpered (e.g. a SATA 2 disk on a SATA 1 configured port is likely to malfunction).
Check that the BIOS is configured to autodetect the hard disk type, and is using the appropriate adapter (EIDE or SATA port), without RAID options or such.
In a pinch, try also ignoring the motherboard labels (e.g., plug the hard disk on the fourth SATA port instead of the first -- the mobo numbering is not always the "logical" one, even if it usually should be.
Jul 02, 2010 | Computers & Internet
At boot up my Hitachi Hard drive clicks once. Not shown in BIOS
I am assuming that this is the hard drive in the computer. Try a safe boot up to see if you can get to the hard drive. use the F8 key at startup for safe mode.
Mar 24, 2010 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
Not deteck hdd & cdrom
Power down you're system and remove the power cable from the PS.
Open you're case. First clear the cmos jumper. See bottom of page 14 in manual. The GA-8VM533M-RZ motherboard was made Jan-1-2004. It is very likely that the cmos battery needs to be replaced. Average life span is 5 years or less. Pull the cmos battery and check its voltage with a voltmeter, it should read no less than 2.7volts DC.
I'm guessing it’s the bios that’s not seeing the CD-ROM drive and the hdd? Suggest you check both the data cables and their power cables.
Since the GA-8VM533M-RZ motherboard only supports ATA IDE hdd's, check the drives jumper. (It should be jumpered as a Master) and so should the jumper on the back of the cd-rom drive. See the link provided;
The link above helps but you're hdd may be different. See the sticker on
you're hdd for the correct jumper setting.
If you are using a single data cable to connect both cd-rom and hdd to the motherboard don't. Use an 80-pin data cable for the hard disk drive. You can use a 40-pin data cable for the cd-rom but if you have a spare
80-pin data cable connect the cd-rom drive to it.
Connect the hdd to IDE1 and connect the cd-rom to IDE2. See motherboard layout in the manual page 5. Need the manual? Download it from Gigabyte;
To view the manual you will need to download and install Adobe reader;
Re-connect the power cable to the PS. You can leave the case opened for now. Power on the system and press the Delete key every 2 seconds until the bios menu opens. (Make sure the time and date are set current). See page 19. Than turn to page 23. Make the settings as follows;
First Boot Device [Floppy] - (if one is connected)
Second Boot Device [CD-ROM
Third Boot device [HHD-0]
Password Check [Not needed]
CPU Hyper-Threading [Enabled]
Check all settings while in the bios, save and exit. The system will auto re-boot. If after replacing the bios battery (If needed), and the bios still
does not see either drive than the problem is either the bios or the motherboard's controller. The bios can be flashed but the MB controller can not be repaired.
Feb 15, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Acer pc disk read error
this error is not usually associated with data loss, DO NOT RE-PARTITION THE DRIVE. Your data is likely safe and sound.
Here's how we'll recover your data. Try each step below, in order, and see if your drive becomes accessible after each step. In my experience, you won't start seeing results until step 5 or so.
1. Run CHKDSK /R /P from the recovery console (it will typically find no error)
2. run FIXBOOT from recovery console (typically has no result)
3. run FIXMBR from recovery console (typically has no result)
4. Run the manufacturer's diagnostic utility, downloaded from their website (it will typically find no error)
5. Changing the drives from cable select to Master/Slave may fix it.
6. Replacing the data cable may fix it, but usually not.
7. Setting the BIOS to use defaults may fix it, but usually not.
8. Changing the BIOS drive settings from auto to user-specified, ensuring that LBA is selected may fix it.
9. Pulling the CMOS battery to let the BIOS lose it settings may work.
Dec 15, 2009 | Computers & Internet
Hello didot05,
It is possible that you may have a deffective hard drive. However, I would suggest checking your IDE cable to make sure they are connected. Then go into your bios mode to see if *********** reconizes the hard drive from there. If you are not able to see the hard drive through your bios, you may have a deffective hard drive and may have to replace the hard drive.
I hope this information helps.
Agent Xiong
Apr 21, 2008 | Computers & Internet
Intel Motherboard Logo
404 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
