F11 is usually a generic code that indicates a communication error between the central control unit and the motor control unit. The first thing I would do is check the connection at the control board. A common problem is the connection jiggling loose. Unplug and reseat the plug and check for any corrosion which is the enemy of good electrical connections. Hope this helped and best wishes.
SOURCE: error message on my kenmore elite smart washer
"F11" is a Serial Communications error between the Central Control UNit (CCU), Motor Control Unit (MCU), Drive Motor and/or interconnecting wiring.
"Fdl" is either a door latch error, communicaiton problem with the CCU, or the interconnecting wiring.
The following two links explain these error codes:
http://www.fixya.com/support/r3608695-f11_error_code
http://www.fixya.com/support/r4490349-fdl_error_code
You can attempt to unplug the washer for at least 30 minutes in an attempt to reset the CCU. Sometimes these error codes can be momentary glitches in the operating program. If the error codes reappear following a CCU reset, then you have a legitimate problem.
The common factor between these two error codes is that it involves the CCU. There's a good chance the problem is with the CCU.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. The Sears website will often carry a refurbished CCU at a lower cost than purchasing a brand new one. The part number will be listed with the letter "R" at the end if available.
If the door remains locked and you need to access, there is a manual release you can use to open the door. The following link epxlains how:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
NOTE: The error codes are NOT listed in the Owner's Manual. For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
SOURCE: my maytag washer when it starts to fill it stops
F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine so if you replaced the CCU then you need to replace MCU (motor control unit)
SOURCE: The washer stopped in the middle of a wash cycle.
Hi An "F-11" error code on a Whirlpool Duet could cause your washer to become inoperable and stop in the middle of a load. The cause of the problem could be a number of things and may require new parts. Identification The "F-11" code could appear with the dash or without the dash on the LCD screen. Be aware that there is also an "F-H" code that could look similar to the "F-11" code. Listen for 11 beeps to go along with the error code's first appearance. Effects The error means that there is no communication between the "Motor Control Unit" and the "Central Control Unit." This means that any operation selected like "Pre-wash" or "Large Load" cannot be sent to the motor for the washer to operate. Prevention/Solution Open up the washer panel to check the wire connections between the two units. If any plugs are loose or unplugged, reconnect them. Check to make sure none of the wires are stripped, rusty or broken off. After you reconnect the wires, rerun the washer to see if the error appears again. Warning If you do not know or understand the inside components of your Whirlpool washer, leave the job to a professional. Contact the store where you purchased the washer or Whirlpool customer service directly. Please get back to us if you have further query else please accept the suggestion.
F11 can mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor.
Thank you for contacting fixya.com
Hi
Identification
Effects
Prevention/Solution
Warning
