I was changing a bulb in a Zephyr Venezia hood. As I changed it, there was the sound of something blowing (fuse maybe). All the lights still work, but now they won't turn off. Is it a fuse or a control panel issue? And can these be replaced?
Comments:
Aug 11, 2009
- Thank you. It was the control panel. Successfully replaced it.
After a brown out three weeks ago we found no power or LCD lights on timer or fan working. I turned...
(More)
After a brown out three weeks ago we found no power or LCD lights on timer or fan working. I turned off all the fuses in the house at the main box and pulled the green button when power was off and clicked it back in. Still no power was about a 2003 model# ZV850SB3SS. Called to GE Cares for new fuse. There seems to be no switch or button to be found near or under hood. Would like reply. Thanks, Maria
I have a Range Hood that I need a part from. The hood has the brandname CATA on the outside which no...
(More)
I have a Range Hood that I need a part from. The hood has the brandname CATA on the outside which no one seems to have heard of. Inside, the compliance plate says it is a FIORI. In any case, I have burnt out one of the down light fittings. Need a replacement part. Any ideas where to get it ? Any supplier of spare parts for range hoods in Perth would be a start. J
4 Lights on the unit not working. Have new bulbs installed and none go on. Any ideas?...
(More)
4 Lights on the unit not working. Have new bulbs installed and none go on. Any ideas? fredmo395@yahoo.com Thanks
