Question about Belkin (F5D7230-4) Router (587009)
IP address The ip address is reset to a belkin ip address therefore my internet will not connect. I need to know how I can stop the wireless router from resetting the ip address. My model # is F5D7230-4
  • Anonymous Nov 27, 2007
    i have lost the dix to the wireless router how would i go about hooking the router back up
  • 25 Answers
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
Posted on Nov 25, 2007
What Is the Default IP Address of Belkin Router? And determine Admin password?
How to Find the Default IP Address of Belkin Router
Oct 24, 2017 | Belkin Computers & Internet
How to connect two ASUS RT-N10 Routers to PPPoe connection?
All routers don't work the same. You have assigned to the second router to an IP address that is outside of the pool. Some routers will not see this. Try assigning the second router to the .50 IP and see if it is identified. If so, you know that is your problem. You can then decide to either reassign the second router's IP to a high address in the pool, or use the .50 IP and in the first router, use the advanced settings to reserve the .50 address to the second router so it will not re inadvertently assigned to another device, causing an IP conflict.
Sep 15, 2012 | ASUS RTN10 wireless router
Im trying to set this up as an access point. but it will not fine a ip from the router
Most router wont act as a DHCP client (Get an IP address) on their own.
You need to go into the Belkin setup and set it to an IP address in the range of your other router.
For example:
If your PC is getting (connected to the same network) an IP address of IP and a Default Gateway address of you can set the Belkin with any adderss between & Changing the last octet (set of numbers after the 3rd period) to the desired address.
Mar 02, 2011 | Belkin Wireless-N Wireless Router with...
I have a embarq 660 series router and using a compaq presario computer. I have already installed the belkin surf/share wireless USB adapter to this laptop. When I go to Internet explorer it says offline.
your problem is a IP address conflict
Embarq and Belkin have the same IP address
change the IP address in to your Router.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Now go to lan settings and change the IP address in to
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
=================== WIRELESS SETTING UP A WIRELESS CONNECTION ====================
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 06, 2010 | Belkin Surf Share Wireless USB Adapters...
Belkin wireless G router incompatible with netgear modem
connect your computer to netgear modem alone and check for the ip address in the computer
(make sure that you have selected "assign ip automatically" in computer)...
to open command prompt type "cmd" and hit enter in run box...
then you can check ip address by typing "ipconfig" in command prompt...
make a note of IP adress or ipV4 address found under the heading "ethernet adapter local area connection"
it might be 192.168.X.X
now connect only the belkinrouter and check for the ip address using the same steps above...
it might be 192.168.2.X
make a note of that...
now compare both the ip addresses if they both have the same value in first three places...that is
192.168.2.... or something like 192.168.1.... or 192.168.0.... then you are facing with double NAT issue...
all that you need to do for that is to change the ip address of belkin router...
if it is change into something like issue will get resolved....if not you can reset the belkin
router by pressing and holding the reset button for 30 seconds using a toothpick when the power is turned on...
Apr 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
BelkinMIMO wireless router stopped connecting to internet
I just installed a Belkin N1 (model F5D8635-4 v1000) to a Comcast Arris modem in SW Florida by resetting the IP on the router to Comcast assigns (but will accept however not .2.1) and Belkin default is Problem is easy enough to correct by following the instructions for changing the default router IP using a Firefox interface as documented in the user's manual. Note that when applying changes it takes about 30 seconds for changes to be effective.
Sep 16, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Router will not return ip address - limited or no connectivity
Try again with static ip.
Then if it is connected then you have restart the DND service of winxp.
For that go to start ->run
type in run "services.msc"
then check in right pane you find DNd client.
Right click on it then stop then again restart it.
Then check .
If still face same problem then go to another pc where internet works fine.
Access your router with following link.
For belkin router
type user name as "admin" and password as "admin" or blank or "password"
Then go to DHCP then enable DHCP then save setting and restarrt router.
Let me know if you need more assistanse.
Sep 01, 2009 | Belkin (F5D7230-4) Router (587009)
F5D7231-4 stopped connecting to Internet via downstream router
Why did you change it from dynamic to static? My suggestion would be to put it back to dynamic and let it grab a good ip address from the gateway. The other option is to contact whoever managed the network at your apartment and see what they will charge you for a static IP address.
May 23, 2009 | Belkin (F5D7231-4) Wireless Router
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
as long as you are not using your own router to connect to your neighbours, as this wont work only one router on the network can connect to the net Im assuming your pc is trying to connect to the neighbours router, so you need to reset the router if you cant access it, it should have no password as default and the ip address of the router should be get into your network cards properties and ensure obtain an ip address automatically on the TCP/IP line is selected. Go into the router settings and make sure enable DHCP is set to allocate ip addresses automatically and that the router transmits on mixed mode b and G, turn off any wep or wpa encryption until you have a connection. Do not use windows connection repair as it will totaly mess up your pc's ip addresses and stop you from connecting to the routers ip address.
Aug 28, 2007 | Belkin (F5D72304F5D7000) Router
Belkin (F5D7230-4) Router (587009) Logo
438 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
