Question about GE Kitchen Ranges
We have a brand new GE Monogram 36" gas range. There is a constant humming noise coming from the back when nothing on the range is even turned on. Goes off when we trip the breaker.
  • Eva Duve Creel
    Eva Duve Creel Mar 06, 2019
    Same problem, brand new after plugging it in the next day constant humming. GE installed a new transformer didn't fix it. GE ordered a third transformer and removed a spacer. Fixed the problem for about 15 minutes. Hums and vibrates loudly and constant if plugged in. Using matches to light and leaving unplugged. GE says it's normal. Completely BS. The transformer is likely coming loose and they don't know how to fix it.
  • GE Master
  • 2,824 Answers
If it's brand new I would talk to the people you bought it from and see what they suggest. Even have them come out and see it and see if something is out of wack.
Posted on Aug 23, 2018
SOURCE:
reg501
  • 413 Answers
SOURCE: Gas Range Continuous Spark
On all gas stoves/cooktops, when you switch on one burner to light, all other burner igniters will click at the same time. This is normal. Enjoy your new apartment!
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 05, 2008
SOURCE: GE Monogram freezing food
I got the same problem.
Temperarily solution:
Open the top hook overnight and you will see the temperature will return to normal i.e. 1 degree F
I suspect there is the thermostat or some type of thermal sensor that prevent the freezer to operate during summer time
Hope it help
Posted on Jul 28, 2008
geemarie
  • 876 Answers
SOURCE: GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Posted on Aug 01, 2008
meztang
  • 112 Answers
SOURCE: Premier Pro•Series 36" Model P36S318BP
Sounds like you have shorted out the ignitor module and you may need to replace it. Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into. Hope this helps.
Posted on Jul 16, 2010
SOURCE: humming noise from stove
Turn the convection oven switch to the off position.
Posted on Oct 26, 2010
Diagrams monogram zv750s
Go to the G.E. Website and the diagrams there.
Jul 06, 2014 | General Electric GE Monogram 36""...
Ge monogram fan dying slow death...first hi-spd. only, now only humming, lights work...is it fuse, transformer or worse, blower assembly
My best guess is the blower motor is going out -- probably the bearings. You might be able to replace just the motor excluding the propeller or the squirrel cage as the case maybe.
Oct 08, 2012 | General Electric GE Monogram 36""...
I have a 48" GE Monogram 4 burner with griddle gas/ duel fuel range (ZDP48N4GD1SS) that was set up for natural gas. I need to convert it to LP but the parts website doesn't show a conversion kit for this...
I just bought a new/used GE mongram natural gas range and need an LP conversion kit. Called GE and found them very UNhelpful. Can this be this hard? The party I called will not take the range back. $3000! I thought I got a great deal and cannot use the range the way it is. I need help too.
Aug 19, 2010 | GE Monogram ZDP48N4GHSS Stainless Steel...
36" SxS not cooling
unplug it for five minutes... if it dosent come back on the pc board must be replace....
Apr 09, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Gas burners lit, but electronic ignition still clicks
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
fsggfs
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Tin foil stuck to bottom of new ge monogram oven
I had the same thing just occur. GE is now telling me the only fix is to buy a new range. Great. $10K for a range that I use once.
Jan 04, 2009 | GE Monogram ZDP48L4GHSS Dual Fuel...
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
Regards,
reg501
Jul 04, 2008 | Cooktops
I have a ge profile gas range and the burners are making a constant clicking noise and spark. The only way to stop it is by either unplugging it or turning the power off to it
Under each gas control is a switch that will turn on the spark module when rotated to the light position. One or more of these switches has failed. Some models these switches are individually replaceable, others the switch is an assembly of all four.
Jun 15, 2008 | Whirlpool SF368WWH Gas Kitchen Range
Kitchen Ranges Logo
142 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
