Question about Magic Chef MCWC30MCG Compact Wine Cooler
We have a Magic Chef MCWC52B
It started making a clicking noise a couple of days ago and now the fridge will not cool. The light works but the clicking continues. We have had the fridge for 2 and 1/2 years and have never had a problem until now. Does anyone know what the problem might be or how to fix it.
Thanks
Damsel in Distress
  • 1 more comment
  • cccvargas Dec 02, 2007
    The Clicking noise comes from the circular black, metal object at the bottom of the back side of the fridge. Does that sound like the compressor or the relay? How do I make sure?
    Damsel
  • cccvargas Dec 04, 2007
    OK I took the casing off the relay but could not unplug or loosen it from the compressor. We have a Magic Chef MCWC52B...I'm not sure how to detach the relay from the compressor with this model...? I did plug it back in after removing the casing and this time when it clicked, I could see a green light flicker coming from the relay. The relay also got warm once it was plugged in...
    Need more help! Thanks
  • Bud Fleck
    Bud Fleck May 17, 2014
    The relay should pull out from the compressor straight to the left as you're facing it. What happens most often is there is a small disc inside the relay that gets oxidation on the surface which causes it to fail. What you need to do is remove the cover on the relay by prying off the C shaped clip. Once open you pull the disc out and rub both sides with fine grit sandpaper until clean then reassemble. If the disc is broken then replace the whole relay.
  • 290 Answers
Can you tell where the clicking is coming from?
There is a relay switch on the compressor that will click if it shorts out or if the compressor locks up.
It could also be a thermostat problem.
Thanks/Mike
Posted on Nov 30, 2007
  • 2 more comments
  • Michael  Lindley
    Michael Lindley Dec 01, 2007
    Damsel,
    Have you found your problem yet?
    If it is the compressor that is locked up, it should still be covered by the 5 yr compressor warranty. You can find your warranty and service information here,
    http://www.magicchef-ewave.com/
    If it is the relay that has failed, you can replace it easily. You can find the part also at this site or at repairclinic.com.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Dec 03, 2007
    That circular object is the compressor. The relay plugs onto the compressor and the wires plug to the relay.
    Without test equipment, the only way to know which part you need for sure is to replace the relay.
    You can unplug the relay from the compressor and shake it. If it rattles like it has come apart inside, then it is burned out.
    If you replace the relay and still have the same problem, call for warranty service on the compressor. You should be able to buy the relay for around $20. It will cost over $200 to have a repair service come out and replace it.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Dec 04, 2007
    The relay just unplugs from the compressor.
    There are 2 pieces there. The relay is the brown piece and the overload is the white piece. If you saw a spark, the relay is most likely shorted out. If the compressor is locked, you won't usually see a spark, it will just hum a few seconds and click off. It would be good to replace the relay and overload both, the overload may be weak from clicking off so many times.
    If you are going to unplug the wires from the relay before you have the new one, make yourself a note as to which wires plug where so there is no confusion if the replacement has a different number of terminals.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Dec 27, 2007
    Just wanted to follow up on your problem and see if you got it fixed. Since you didn't rate either solution, the first answer got credit for solving your problem.
    Thanks/Mike
  • 83 Answers
The light may be old, and need repairing, I would try contacting somebody local rather than buying a new one.
Popping noise
it's the aluminum defroster coils cooling after a defrost cycle.
a padded aluminum foil-covered mat installed behind the defrost heater in the back of the fridge is a fix at least for Samsung I know.
Jan 07, 2018 | Magic Chef CTB2125 Top Freezer...
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
Stops periodically
possible compressor or fan overheating and shutting off
Dec 08, 2017 | Magic Chef MCBR445S1 Stainless Steel...
MCBR240s Magic Chef Fridge does not cool. Compressor gets very hot when plugged in, but no cooling, it also makes clicking noises
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 10, 2011 | Magic Chef MCBR440 Compact Refrigerator
I have a similar magic chef wine fridge, and have had the same loud popping noise every 15-20 minutes. Its model # MCWC52B. I have had 2 different repair people out to fix, and both have said call Magic...
I have practiced this tactic for years and it has never failed. Call Magic Chef and ask to speak to a management member that is in charge of repair issues. Explain to them the issue. Tell them that you don't want a repair tech any more, you would like them to ship you a comparable unit and replace the one that you have. They can come out with the new unit and take back the broken unit and repair it in their shop, trial and error and instruct their techs as how to repair these in the future. If they won't do that, ask to speak to their supervisor and keep going up the food chain. They will cooperate, trust me. Let us know how that works for you. Be frustrated and firm.
Jul 15, 2017 | Magic Chef MCWC45A Wine Cooler
MCWC52B wine cooler stopped cooling, compressor hot
Turn it off and place a small electric fan by compressor to cool it down.
When you turn it back on, see if you hear a clicking noise. This would indicate starting components need checking.
Nov 08, 2010 | Magic Chef MCWC45A Wine Cooler
Mcwc52b problem with cooling
I would try replaceing the overload/relay first . The piece that plugs onto the compressor . Without model number , cant give you the part number .
Jul 24, 2009 | Magic Chef MCWC45A Wine Cooler
Where can I find magic chef wine cooler compressor for MCWC52B
My Name is Mike. I have the same unit. The compressor is not bad. Replace the start relay& overload on compressor.
Mar 31, 2009 | Magic Chef MCWC45A Wine Cooler
Re: Magic Chef
If the compressor is running but the fridge is not cooling, the gas may have leaked out of the system or the compressor is inefficient. The only way to know for sure is to connect a set of gauges to the system. You will need to call in a Refrigeration Mechanic.
Nov 03, 2007 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef MCWC30MCG Compact Wine Cooler Logo
1,101 people viewed this question
Top Magic Chef Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
